Teamcenter 11.2 .Net webtier install success, but get error Tcp channel protocol violation: expectin
Dears
I have installed teamcenter 11.2 with .net webtier on iis 7 and windows server 2008r2, after installed it i got this error on my browsers
.NET�����������Á��System.Runtime.Remoting.RemotingException: Tcp channel protocol violation: expecting preamble.
   at System.Runtime.Remoting.Channels.Tcp.TcpSocketHandler.ReadVersionAndOperation(UInt16& operation)
   at System.Runtime.Remoting.Channels.Tcp.TcpServerSocketHandler.ReadHeaders()
   at System.Runtime.Remoting.Channels.Tcp.TcpServerTransportSink.ServiceRequest(Object state)
   at System.Runtime.Remoting.Channels.SocketHandler.ProcessRequestNow()����
Please help me to solve itt.
Re: Teamcenter 11.2 .Net webtier install success, but get error Tcp channel protocol violation: expe
It's likely a port conflict. Sometimes it is related to hardware issues like a Load Balancer routing packets to the wrong server or a Network Card issue. Disable firewall and virus scanners temporarily while testing in order to eliminate them as possible sources of the error.
Evaluating: AW 3.4
Dear Randy
I dont have antivirues and i disabled all firewalls, and dont have any problem with network card,
but i am not success with your way,
Please help me with another way to solve it,
Have you tried a different port number?
Evaluating: AW 3.4
Yes i changed from 8085 to 8093
and all port is are opening and i check it with netstat
I don't know how your client is sending TCP over an HTTP connection (hence, the error). Try uninstall/re-install the .NET Web Tier and ensure that your have the correct Roles enabled.
https://docs.plm.automation.siemens.com/tdoc/tc/11.3/help#uid:xid1256814:index_server_win:paratentpr...
Evaluating: AW 3.4
Hi ,
i need some help or some guide to configure load balancer for teamcenter 11.2, Can you guide from where i can get some information like how to configure it for multiple hosts & pool
