Teamcenter 11.2 installation
I am new to Teamcenter.
we need to install Teamcenter 11.2 on windows server,
1.I checkTeamcenter Software Certifications file, but the tool list is very big (listed below) .
 Could you please suggest the required Software?
Windows Server x64
.NET Web Tier IIS Server
Autonomy IDOL Server
C++ (includes C#)
CORBA
FMS
Geolus Toolkit
GhostScript
HyperV
IBM DB2 DB
IBM DB2 client
InstallShield
JBOSS Enterprise Edition
JT Utilities
Java - JAXB
Java - JDK
Java - JRE
MS SQL DB Client
MS SQL Server DB
Microsoft IIS
Microsoft SharePoint Server
Oracle DB
Oracle client
PLM XML SDK
PLMVis Toolkit
STEP Tool Library
Security Services (TcSS)
Siemens PLM Licensing
SolrDB Search Engine
TSTK
TcCrypto
Tivoli Access Manager LDAP
Tomcat
VMware ESXi
WebLogic Server
Websphere
Xerces/Xalan/ICU C
Xerces/Xalan/ICU Java
2. Hardware configuration requirment  ( Processor, RAM,Hard disk)
3. what is the diff between Two tire and Four tire setup, which is sutable for small team ( upto 10 users)
thanks in advance.
-Sekar
Re: Teamcenter 11.2 installation
1. These all requirements are for different modules which you install on requirement basis. To get started, you need a Database and JRE.
2. Not sure if all of this is specified by Siemens. Hard disk requirement is specified here
https://docs.plm.automation.siemens.com/tdoc/tc/11.2/help/#uid:index_server_win:c01a0001_v3:id267886...
3. In 4-Tier, server-client communication happens over HTTP protocol. A Server manager and a web application server is needed in addition. For a few no. of users, 2-Tier is normally used.
