Teamcenter Custom Shortcuts
You can customize some applications shortcuts by creating an empty java plugin project (empty handler class) but writing some code in its plugin.xml doc. You can fill plugin.xml like this:
<plugin>
<extension point = "org.eclipse.ui.bindings">
<key commandId = "com.teamcenter.rac.workflow.processviewer.sendto"
          schemeId = "com.teamcenter.rac.scheme" sequence = "M1+M2+J"/> <!--send to workflowviewer-->
<key commandId = "com.teamcenter.rac.pse.sendto"
          schemeId = "com.teamcenter.rac.scheme" sequence = "M1+M2+P"/><!--send to structure manager->
</extension>
</plugin>
