Teamcenter - Data Share Tool
Hello community,
I would like to ask you which SW you will recommended for Sharing data between Company and it's customers.
Requirements:
- sftp
- possible to implement to Teamcenter
- UI for Customers
I was thinking about SDX / DDXm, Briefcase or is there any Siemens product or recommended SW by Siemens?
Thank you for your cooperation
Re: Teamcenter - Data Share Tool
Teamcenter is not designed to be a public facing Content Management System (CMS). However, there are plenty of CMS's to choose from. A good CMS that works with Teamcenter is Cortona3D RapidAuthor. It would be easy to publish to a public web site using Cortona3D.
https://www.plm.automation.siemens.com/en/products/teamcenter/document-content-management/technical-...
Evaluating: AW 3.4
