Teamcenter ITK Error Codes
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
I get the following error from my custom ITK client -
STATUS after POM_ask_group_tag = 515142
Anyone know where(file path) the Teamcenter ITK error codes are listed ?
Roy
Re: Teamcenter ITK Error Codes
You will find the error codes in the header files in the include directory
here it must be something wrong with the group name as input
POM_ask_group_tag(const char *group_name_string, tag_t *group_tag)
Name given is not a known group. Check that the group does exist.
#define POM_unknown_group (POM_error_base + 142)
and you find them in the text files under %TC_ROOT%\lang
e.g. inside pom_errors.xml
<textsrv filename="pom_errors.xml">
<errors module="pom" error_base="515000">
<error id="142">The given group is unknown.</error>
Siemens Pioneer
Yes.    Thanks !
I was searching for the entire code,  and did not realize there was a generic prefix (i.e. 515 ).
grepping for '142' found the codes.
