Teamcenter Integration for Digital Project from Gehry Technologies
Hi, All
Our potential customer is using Digital Project from Gehry Technologies for their business designing and engineering Curtain Wall product.
AFAIK, Digital Project (http://www.digitalproject3d.com) is a 3D design tool for AEC division industrialized by Dassault Systems based on CATIA V5 cooperation with Gehry Technologies (http://www.gt-global.com)
My question here is that does TCIC cover Digital Project including OTW distribution?
The TC version will be 11.2.2.1, TCIC will be 11.0.1, JT Translator will be 11.0.1 and the Digital Project will be V1 R5 SP2 HF8 (it seems like the base CATIA Version is V5 B22 with same SP/HF number)
If there is any experiences or guidance, sharing it will be highly appreciated.
Thanks in advance.
Re: Teamcenter Integration for Digital Project from Gehry Technologies
can you provide more details about what Data types Digitial Project use? is it same like CATPart/CATProduct?
Digital Project is supported by TcIC required that CAA objects of TcIC should source in Digital Project Env file.
now what do you mean by "does TCIC cover Digital Project including OTW distribution"? .. Do you mean TcIC with OTW should install digital project also or TcIC should install on digital project application only?
can you clarify the exact requirement?
