Teamcenter_Integration_for_SolidWorks_11.3.1_WIN64
Hello Everyone,
Does anyone know if I can directly install the 11.3.1 integrator or do I need to install 11.3 first and upgrade afterward?!
Thanks for all comments!
Best Regards,
Re: Teamcenter_Integration_for_SolidWorks_11.3.1_WIN64
complementing my question:
Looking for the Readme (link bellow) found with the Teamcenter_Integration_for_SolidWorks_11.3.1_WIN64.zip - 91,424,567 bytes - Jan 27, 2017.
( https://downloada.industrysoftware.automation.siemens.com/product_download/teamcenter/product_update...
We can see that " It is not necessary to install any previous versions of this product prior to installing this patch".
But, "Install as noted in the Teamcenter Integration for SolidWorks Installation Guide Version 11.3.0".
https://download.industrysoftware.automation.siemens.com/download-n.php/teamcenter/full_products/Int...
And there is a procedure using TEM where we have: ""Follow these steps if the Teamcenter Integration for SolidWorks is already installed in the selected configuration, and you are updating to a newer version of the integration. You should always perform this step whenever upgrading to a new version of the Teamcenter Integration for SolidWorks".
Does Someone know about it?
Thanks again!
I think, You can directly install SWIM 11.3.1 even if you dont have SWIM 11.3.0,
But in case you already have SWIM 11.3.0 you can update that to SWIM 11.3.1
