Teamcenter Nagios monitoring
Please help me to get TeamcenterNagios package, I searched in GTAC but unable to find the plugin to configure Nagios agent.
Re: Teamcenter Nagios monitoring
I'm not aware of a Nagios plugin. Nagios monitors services and you can configure it to monitor Teamcenter services. You can write more complicated monitoring as long as you're using J2EE (not .NET). Nagios uses an agent installed on the servers to achieve this.
Evaluating: AW 3.4
TeamcenterNagios JMX plugins utilize a Java-based server process (called TcJMXProxyServer) that is always running on the Nagios Machine.
And where did you find TcJMXProxyServer?
Evaluating: AW 3.4
From what I've understood it's provided by Siemens if you engage the Services team.
You are correct. It is something you pay SPLM Services for...
https://www.plm.automation.siemens.com/fr/advantedge-services/technical-services/teamcenter-system-m...
Evaluating: AW 3.4
Done this setup in past for TC 11 where the plugins provided. Want to do  the same for TC 10.1.5_a01_patch_2. Dont know whether those plugins will work with 10.1.5_a01_patch_2. I will try with those(TC 11) plugins first. Thank you.
We have developed a way to monitor Teamcenter application usage by ourselves which has been validated to work with TC9.1, TC10.1 and TC 11.2. Currently we are able to monitor the amount of users in system as well as statistics from FSC servers. One neat feature is also dispatcher monitoring (the amount of requests and their statuses as well as passthrough times from certain translators.
All the data can be visualized by using different scales and time windows.
All normal monitoring are included of course (OS level and network level). I included some sceen captures from the system.
Very basic graph from system users
Example graph. Dispatcher queue.
Example table. FSC hit rates
Please let me know from where I will get the manual to configure the Teamcenter monitoring with the way you have developed? Currently, we have to stick to Nagios due to customer requirement. But your way will be helpful in future projects. Thank you.
