Teamcenter POM_Schema
I am giving a shot to generate some custom queries in Teamcenter 10.1. Currently struggling to find a resource where i can refer the Teamcenter POM Schema.
Does anybody have some pointers / references ?
Thanks for your response.
Cheers!
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
4 REPLIES 4
Re: Teamcenter POM_Schema
You can run utility taxonomy which will give you POM class hierarchy in character-mode summary.
Thank you for your response,
Appreciate any pointers / resources about this utility.
Cheers.
Teamcenter 10.1.7
There are two usages for the taxonomy utility.
The first is a brief taxonomy:
taxonomy -u=infodba -p=infodba -g=dba -b -f=C:\Temp\tc_tax_brief.txt
The second is a full taxonomy by omitting the -b argument:
taxonomy -u=infodba -p=infodba -g=dba -f=C:\Temp\tc_tax_full.txt
The brief tax will shows classes and level in the scchema while the full will show the classes in a indented hierarchy and the attributes.
Best,
/Randy
Evaluating: AW 3.4
Thank Randy and Kim,
This is what exactly i was looking for.
Cheers,
TCNinja
Teamcenter 10.1.7
