Teamcenter-Solide Edge Integration
Hello ,
where can I download this integration ?
Couldn't find it on the GTAC download portal and google search leads only to articles or videos.
Thanks!
Re: Teamcenter-Solide Edge Integration
under Solidedge - data management (SEEC)
On ST10, the client side is installed when SE is installed. It is no longer an additional install on the client side. You still have to download & install the SEEC Adminstrator on the server.
Jamie
Thank you for your responses.
I was expecting it to be in "Integrations and Solutions" folder under Teamcenter, but it does not seem to be so.
I think Solid Edge is not included in current contract of my employer, that's why I cannot see it on download server.
Check your SELicense.dat file, it should have a contact name and email id. Only that user will have access to download
ST10 Download:
https://download.industrysoftware.automation.siemens.com/download.php
Check this below thread regarding ST10 download
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Solid-Edge-ST10-Download-Availabili...
Rafa
