Teamcenter Visualization licensing
Hello All,
Does anyone know if there is a way to determine what users or what machines are occupying which level of visualization license?  If anyone might know of a way to get this information other than going around to each workstation and checking manually, I would sincerely appreciate it.
Thank you in advance.
All input is encouraged!
Jake
Re: Teamcenter Visualization licensing
Is there a FlexLM license log? For those that haven't signed into TcVis yet ... you can check client_specific.properties for the assigned license level. Unfortunately, TcVis installs ALL the software so you can't just check the install location.
Evaluating: AW 3.4
from the server where you installed the visualization folder there should be a logs with all this details please dig on the logs cause I forgot the exact log name..
Thank you for your replies, I have located the correct log file and was able to resolve my issue.
Jake
