Teamcenter Webclient cannot access with IIS and .Net based server
 Hi there,
 I have installed TC 4-tier and I want to access the link localhost:80/tc. However, when I access the link, I got the issue as below.
 After I fix the issue that follows the browser suggestion, I can access the link. However, it just shows the directory.Screen Shot 2019-01-09 at 2.30.32 PM.png
 Do you have any suggestions for my case?
 Thanks in advance. :D
14 REPLIES 14
Re: Teamcenter Webclient cannot access with IIS and .Net based server
use http://baont:80/tc/webclient
 Hi @Roman65,
 I have tried this link, but it's still not working. :(
Ok,
than you need some other expert, because we are using JBoss/Tomcat
no experience with IIS and .NET based server
Siemens Legend Siemens Legend
Siemens Legend
Please verify that you have all the required roles installed on IIS:
Here's the doc for TC and TCRS 12, but the other versions have a similar section in the server installation guides:
https://docs.plm.automation.siemens.com/tdoc/tc/12/help/#uid:win2008_server_config
https://docs.plm.automation.siemens.com/tdoc/tc/12/help/#uid:xid1256814:index_server_win:paratentpre...
Good afternoon. Can you open the webclient from the server itself by running a browser on it and go http://localhost:80/tc/webclient ?
Are you sure you specified port 80 when installing WebTier? Try using port 7001
 Hi Arthur,
 I have tried to open the webclient by your suggestion. But, it still doesn't work to me. :(
 I have installed my Teamcenter using the port is 80.
 Thanks @TheGAP. I will check on these guides. :D
Siemens Genius Siemens Genius
Siemens Genius
if you are using TC 12 then webclient is obsolete, as the thin client you can use only AWC
All the best, Alexey.
 Looks like @SedoykinAlexey is right
General obsolete feature announcements
https://docs.plm.automation.siemens.com/tdoc/tc/12/help#uid:id1470050
