Teamcenter installation error - step 5 of 120
The installation program errored on step 5 of 120 with the following information. Any inputs what it is suggesting (highlighted in red) to do and what to do here?
GErrorStep5of120_TCServerInstallation.pngautham
1 REPLY 1
Re: Teamcenter installation error - step 5 of 120
Hello, you looked at the error in the general setup log, now you need to look at the log of the utility bmide_schema, which is located on the path E:\Programs\Siemens\TC11\logs\1807140035\tc_install.log
Check it for errors or post it here
