Teamcenter integration with ICAD
Dear All,
I have problems integrating ICAD with Teamcenter. As far as I know, Teamcenter cannot integrate with ICAD.
Is there any solution to this problem?
I appreciate any help and support for this issue.
Thank you,
Re: Teamcenter integration with ICAD
If you've already talked to GTAC then its likely that none of the exiting connectors will work. T4EA will give you a way to sync meta data but likely not CAD. The reason there is no connector is likely because ICAD doesn't expose their code so we can't write a connector to Teamcenter.
Evaluating: AW 3.4
