Teamcenter project data import
Dear all,
           I am going to create a new project in teamcenter. And later i have to impoort the data related to project to work into the teamcenter . Can please let help me that how can we import project data into teamcenter and how can we assign them to the particulars to work.
thanks
3 REPLIES 3
Re: Teamcenter project data import
Can you explain more of what you'll be importing later? It is Items & datasets, etc? What is the method of importing? Are you going to use Owning Project or just want them tagged to the Project List? I have done some of this before but with a TCXML migration.
Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
I want to import some dump model data and some detailing documents but the thing is there are in bulk like 100s may be. So I can't import them all as individual .so is there a solution?
Is the data being imported into existing Items or you are creating new Items on the import? There is a solution but I need to know more about your situation to suggest a path.
