Teamcenter schedule manager:- How to modify default task notification text
I have used "374-newsletter" document which is available on gtac solution center to modify the default text for the schedule task notification rule "When the Tasks status has changed". but it won't reflect on rich client. I have used teamcenter 11.4. I have attached the document provided by gtac.
Anyone who tried to changed default text. please help me for the same
Thanks in advance!!
5 REPLIES 5
Re: Teamcenter schedule manager:- How to modify default task notification text
Any help from this forum?????
Good afternoon, according to the instructions you had to change tc_text_locale.xml and usually, in order for these changes to take effect, you must perform the client cache regeneration:
To do this, if you are using 4-Tier, stop the server manager service (for 2-Tier close the rich client and the TAO ImR window) and delete the shared cache folder by deleting the folder %temp%\V11000.xxxx_xxxxxxx.xx and run the following commands on the server for Client Cache Regeneration:
generate_client_meta_cache -u=infodba -p=<password> -g=dba -t delete all
generate_client_meta_cache -u=infodba -p=<password> -g=dba -t generate all
Thank you very much!!!
It works
My next challenge is, I want to update ResourceAssignment user names in text message each time mail is sent.
Will it be possible??
If Yes then what is the keyword i want use in text file to update ResourceAssignment as like task name keyword is '{TaskName}' in text message.
Anyone tried this??
Anybody got solution??
