Teamcenter syslog file disappears
Builder
Builder
I am running a commandline utility to import files. The syslog gets generated and immediately dissapears once the command execution is complete. There are few errors which i need to check in syslog.
Any suggestions/help would be helpful.
Santosh
Re: Teamcenter syslog file disappears
set environment variable
SET TC_KEEP_SYSTEM_LOG=1
Builder
Builder
It worked. Thanks
Santosh
