Teamcenter10 installation error
Builder
Builder
Hello Team,
While Installing Teamcenter 10 with volume,corporate and 2-tier rich client
we have SPLM license server 9.1 and splm8.lic which is updated recently to allow install TC12.
when am trying to install TC10 am getting below errors please let me know why am getting such kind of errors.
Executing [set SPLM_LICENSE_SERVER=28000@USBOU1-SVM01]
Executing ["C:\Siemens\Teamcenter10\bin\check_license_server_version" -appversion 10000.1.0.51]
Output from command: "C:\Siemens\Teamcenter10\bin\check_license_server_version" -appversion 10000.1.0.51
'"C:\Siemens\Teamcenter10\bin\check_license_server_version"' is not recognized as an internal or external command,
operable program or batch file.
command_exit=9009
Exit Status 9009, elapsed time 0:00:00
An error occurred during execution. Stack trace follows...
com.teamcenter.install.tceng.base.Foundation.validateLicenseServer(Foundation.java:1859)
com.teamcenter.install.tceng.base.Foundation.install(Foundation.java:136)
com.teamcenter.install.tem.tasks.JavaTask.execute(JavaTask.java:162)
com.teamcenter.install.tem.tasks.Task.execute(Task.java:135)
com.teamcenter.install.tem.tasks.blocks.CodeBlock.execute(CodeBlock.java:201)
com.teamcenter.install.tem.struct.TcFeature.processAction(TcFeature.java:1348)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1286)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1190)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1104)
com.teamcenter.install.tem.struct.TcFeature.install(TcFeature.java:1029)
com.teamcenter.install.tem.director.actions.InstallAction.execute(InstallAction.java:29)
com.teamcenter.install.tem.director.DirectorScript.execute(DirectorScript.java:143)
com.teamcenter.install.tem.director.Director.run(Director.java:120)
java.lang.Thread.run(Thread.java:748)
*** CANCELLED
Installation interrupted due the following reason:
Processing <install> of feature Teamcenter Foundation failed: Failed to validate the version for license server 28000@USBOU1-SVM01. Return value = 9009.
8 REPLIES 8
Re: Teamcenter10 installation error
Siemens Genius Siemens Genius
Siemens Genius
What about your PLMLicenseServer logfile (splm_ugslmd.log), is there anything strange?
Also, expecting that your Environment variable SPLM_LICENSE_SERVER is corectly set to 28000@USBOU1-SVM01
Best regards,
Miloslav Weitz, Teamcenter Consultant, Siemens PLM Software Czech Republic
Production: Teamcenter 11.5, NX 12, Geolus 9.1
Development: N/A Testing: Teamcenter 12.2, NX 1863, Geolus 10.0
Builder
Builder
@MilaWeitz
Nothing strange its as usual i checked the license server, recently we updated the splm8.3 to 9.1 version.
everthing looks fine.
Siemens Genius
Curious if you try installation of Tc12, if it comes same error.
If not, the license file could be invalid for Tc10.
Best regards,
Builder
Builder
Hi @MilaWeitz ,
Installation of Tc12, it came  same error.
am confused why it is happening like this.
Siemens Genius
post also the splm_ugslmd.log
Best regards,
Builder
Builder
Hi @MilaWeitz
9:34:54 (lmgrd) -----------------------------------------------
9:34:54 (lmgrd) Please Note:
9:34:54 (lmgrd)
9:34:54 (lmgrd) This log is intended for debug purposes only.
9:34:54 (lmgrd) In order to capture accurate license
9:34:54 (lmgrd) usage data into an organized repository,
9:34:54 (lmgrd) please enable report logging. Use Flexera Software LLC's
9:34:54 (lmgrd) software license administration solution,
9:34:54 (lmgrd) FlexNet Manager, to readily gain visibility
9:34:54 (lmgrd) into license usage data and to create
9:34:54 (lmgrd) insightful reports on critical information like
9:34:54 (lmgrd) license availability and usage. FlexNet Manager
9:34:54 (lmgrd) can be fully automated to run these reports on
9:34:54 (lmgrd) schedule and can be used to track license
9:34:54 (lmgrd) servers and usage across a heterogeneous
9:34:54 (lmgrd) network of servers including Windows NT, Linux
9:34:54 (lmgrd) and UNIX.
9:34:54 (lmgrd)
9:34:54 (lmgrd)
9:34:54 (lmgrd)
9:34:54 (lmgrd) Server's System Date and Time: Sun Apr 14 2019 09:34:54 Mountain Daylight Time
9:34:54 (lmgrd) pid 1088
9:34:54 (lmgrd) SLOG: Summary LOG statistics is enabled.
9:34:54 (lmgrd) Done rereading
9:34:54 (lmgrd) FlexNet Licensing (v11.15.0.0 build 215548 x64_n6) started on USBOU1-SVM01 (IBM PC) (4/14/2019)
9:34:54 (lmgrd) Copyright (c) 1988-2017 Flexera Software LLC. All Rights Reserved.
9:34:54 (lmgrd) World Wide Web: http://www.flexerasoftware.com
9:34:54 (lmgrd) License file(s): C:\Program Files\Siemens\PLMLicenseServer\splm9.lic
9:34:54 (lmgrd) lmgrd tcp-port 28000
9:34:54 (lmgrd) (@lmgrd-SLOG@) ===============================================
9:34:54 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
9:34:54 (lmgrd) (@lmgrd-SLOG@) Start-Date: Sun Apr 14 2019 09:34:54 Mountain Daylight Time
9:34:54 (lmgrd) (@lmgrd-SLOG@) PID: 1088
9:34:54 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.15.0.0 build 215548 x64_n6 ( build 215548 (ipv6))
9:34:54 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
9:34:54 (lmgrd) (@lmgrd-SLOG@) Listening port: 28000
9:34:54 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
9:34:54 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
9:34:54 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
9:34:54 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\Program Files\Siemens\PLMLicenseServer\splm9.lic -l C:\Program Files\Siemens\PLMLicenseServer\splm_ugslmd.log -z -s
9:34:54 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:\Program Files\Siemens\PLMLicenseServer\splm9.lic
9:34:54 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
9:34:54 (lmgrd) Starting vendor daemons ...
9:34:54 (lmgrd) Started ugslmd (pid 2044)
9:34:54 (ugslmd) FlexNet Licensing version v11.15.0.0 build 215548 x64_n6
9:34:55 (ugslmd) SLOG: Summary LOG statistics is enabled.
9:34:55 (ugslmd) SLOG: FNPLS-INTERNAL-CKPT1
9:34:55 (ugslmd) SLOG: VM Status: 4
9:34:55 (ugslmd) SLOG: FNPLS-INTERNAL-CKPT5
9:34:55 (ugslmd) SLOG: TPM Status: 0
9:34:55 (ugslmd) SLOG: FNPLS-INTERNAL-CKPT6
9:34:55 (ugslmd) Server started on USBOU1-SVM01 for:
9:34:55 (ugslmd) MILLFOUND (consisting of: MILLFOUND_3d_to_2d_flattener
9:34:55 (ugslmd) MILLFOUND_assemblies MILLFOUND_cam_base MILLFOUND_cam_facets
9:34:55 (ugslmd) MILLFOUND_cavity_milling MILLFOUND_drafting MILLFOUND_dxf_to_ug
9:34:55 (ugslmd) MILLFOUND_dxfdwg MILLFOUND_features_modeling MILLFOUND_fix_axis_surf_mill
9:34:55 (ugslmd) MILLFOUND_flow_cut MILLFOUND_free_form_modeling MILLFOUND_gateway
9:34:55 (ugslmd) MILLFOUND_geometric_tol MILLFOUND_gmc MILLFOUND_graphical_tool_path
9:34:55 (ugslmd) MILLFOUND_grip_execute MILLFOUND_iges MILLFOUND_nc_external_program
9:34:55 (ugslmd) MILLFOUND_nc_wizard_builder MILLFOUND_nurb_output_enabler MILLFOUND_nx_flexible_pcb
9:34:55 (ugslmd) MILLFOUND_nx_freeform_1 MILLFOUND_nx_freeform_2 MILLFOUND_nx_isv_mtb
9:34:55 (ugslmd) MILLFOUND_nx_nastran_export MILLFOUND_nx_post_config_adv MILLFOUND_nx_sheet_metal
9:34:55 (ugslmd) MILLFOUND_nx_spsd_stress MILLFOUND_nx_spsd_vibration MILLFOUND_nx_wi_authoring
9:34:55 (ugslmd) MILLFOUND_pcf_package_file MILLFOUND_planar_milling MILLFOUND_probe
9:34:55 (ugslmd) MILLFOUND_pstudio_auth MILLFOUND_pstudio_cons MILLFOUND_pv_ugdatagenerator
9:34:55 (ugslmd) MILLFOUND_routing_base MILLFOUND_shop_doc MILLFOUND_sinumerik_spline
9:34:55 (ugslmd) MILLFOUND_sla_3d_systems MILLFOUND_solid_modeling MILLFOUND_step_ap203
9:34:55 (ugslmd) MILLFOUND_step_ap214 MILLFOUND_studio_render MILLFOUND_studio_visualize
9:34:55 (ugslmd) MILLFOUND_surface_milling MILLFOUND_tol_cavity_milling MILLFOUND_ug_checkmate
9:34:55 (ugslmd) MILLFOUND_ug_holemaking MILLFOUND_ug_kf_checker MILLFOUND_ug_kf_execute
9:34:55 (ugslmd) MILLFOUND_ug_library_access MILLFOUND_ug_nas_des MILLFOUND_ug_post_exe
9:34:55 (ugslmd) MILLFOUND_ug_post_kinematics MILLFOUND_ug_post_mill MILLFOUND_ug_smart_models
9:34:55 (ugslmd) MILLFOUND_ug_to_dxf MILLFOUND_ug_to_vericut MILLFOUND_ug_visualize
9:34:55 (ugslmd) MILLFOUND_ug_web_express MILLFOUND_ugopen_menuscript MILLFOUND_usr_defined_features)
9:34:55 (ugslmd) NX11110 (consisting of: NX11110_3d_to_2d_flattener
9:34:55 (ugslmd) NX11110_assemblies NX11110_drafting NX11110_dxf_to_ug
9:34:55 (ugslmd) NX11110_dxfdwg NX11110_features_modeling NX11110_gateway
9:34:55 (ugslmd) NX11110_grip_execute NX11110_iges NX11110_nx_freeform_1
9:34:55 (ugslmd) NX11110_nx_nastran_export NX11110_nx_sheet_metal NX11110_nx_spsd_stress
9:34:55 (ugslmd) NX11110_nx_spsd_vibration NX11110_pcf_package_file NX11110_pstudio_cons
9:34:55 (ugslmd) NX11110_pv_ugdatagenerator NX11110_sla_3d_systems NX11110_solid_modeling
9:34:55 (ugslmd) NX11110_step_ap203 NX11110_step_ap214 NX11110_ug_kf_checker
9:34:55 (ugslmd) NX11110_ug_kf_execute NX11110_ug_nas_des NX11110_ug_smart_models
9:34:55 (ugslmd) NX11110_ug_to_dxf NX11110_ug_web_express NX11110_ugopen_menuscript)
9:34:55 (ugslmd) NX13300N (consisting of: NX13300N_3d_to_2d_flattener
9:34:55 (ugslmd) NX13300N_adv_assemblies NX13300N_assemblies NX13300N_design_studio
9:34:55 (ugslmd) NX13300N_drafting NX13300N_dxf_to_ug NX13300N_dxfdwg
9:34:55 (ugslmd) NX13300N_features_modeling NX13300N_free_form_modeling NX13300N_gateway
9:34:55 (ugslmd) NX13300N_geometric_tol NX13300N_grip_execute NX13300N_iges
9:34:55 (ugslmd) NX13300N_nx_freeform_1 NX13300N_nx_freeform_2 NX13300N_nx_nastran_export
9:34:55 (ugslmd) NX13300N_nx_sheet_metal NX13300N_nx_spsd_stress NX13300N_nx_spsd_vibration
9:34:55 (ugslmd) NX13300N_nx_subdivision NX13300N_nx_visual_reporting NX13300N_pcf_package_file
9:34:55 (ugslmd) NX13300N_pstudio_cons NX13300N_pv_ugdatagenerator NX13300N_routing_base
9:34:55 (ugslmd) NX13300N_sla_3d_systems NX13300N_solid_modeling NX13300N_step_ap203
9:34:55 (ugslmd) NX13300N_step_ap214 NX13300N_studio_analyze NX13300N_studio_free_form
9:34:55 (ugslmd) NX13300N_studio_render NX13300N_studio_visualize NX13300N_ug_checkmate
9:34:55 (ugslmd) NX13300N_ug_kf_checker NX13300N_ug_kf_execute NX13300N_ug_nas_des
9:34:55 (ugslmd) NX13300N_ug_opt_wizard NX13300N_ug_prod_des_advisor NX13300N_ug_smart_models
9:34:55 (ugslmd) NX13300N_ug_to_dxf NX13300N_ug_web_express NX13300N_ugopen_menuscript
9:34:55 (ugslmd) NX13300N_usr_defined_features NX13300N_wave)
9:34:55 (ugslmd) SC12500 (consisting of: SC12500_3d_to_2d_flattener
9:34:55 (ugslmd) SC12500_assemblies SC12500_dxfdwg SC12500_features_modeling
9:34:55 (ugslmd) SC12500_gateway SC12500_grip_execute SC12500_id_ext_fem_beam
9:34:55 (ugslmd) SC12500_iges SC12500_nx_freeform_1 SC12500_nx_freeform_2
9:34:55 (ugslmd) SC12500_nx_ftk SC12500_nx_masterfem SC12500_nx_material_system
9:34:55 (ugslmd) SC12500_nx_nastran_export SC12500_nx_nastran_import SC12500_pcf_package_file
9:34:55 (ugslmd) SC12500_pstudio_cons SC12500_pv_ugdatagenerator SC12500_sc_enabled
9:34:55 (ugslmd) SC12500_sla_3d_systems SC12500_solid_modeling SC12500_step_ap203
9:34:55 (ugslmd) SC12500_step_ap214 SC12500_studio_render SC12500_studio_visualize
9:34:55 (ugslmd) SC12500_ug_checkmate SC12500_ug_kf_checker SC12500_ug_kf_execute
9:34:55 (ugslmd) SC12500_ug_smart_models SC12500_ug_web_express SC12500_ugopen_menuscript
9:34:55 (ugslmd) SC12500_usr_defined_features) ansys_meshers borrowing
9:34:55 (ugslmd) gateway_id gfem_ansys gfem_nastran
9:34:55 (ugslmd) ideas_integration mechanisms motion_dyn_lms
9:34:55 (ugslmd) motion_dyn_recurdyn motion_export_adm motion_kin_lms
9:34:55 (ugslmd) motion_kin_recurdyn nx_3d_swept_volume nx_ansys_export
9:34:55 (ugslmd) nx_ansys_export_g nx_ansys_import nx_durability_wiz
9:34:55 (ugslmd) nx_ftk nx_integration nx_masterfem
9:34:55 (ugslmd) nx_nas_basic_dsk nx_nas_bn_basic_dsk nx_nas_nonlin_dsk
9:34:55 (ugslmd) nx_nastran_export nx_nastran_export_g nx_nastran_import
9:34:55 (ugslmd) nx_response_anlys sc_enabled sc_motion_designer
9:34:55 (ugslmd) teamcenter_admin teamcenter_designer ug_nas_bn
9:34:55 (ugslmd) ug_pcb_exchange ug_pcb_modeler ug_scenario
9:34:55 (ugslmd) ug_struct_pe_solver visview_base server_id
9:34:55 (ugslmd)
9:34:55 (ugslmd) Licenses are case sensitive for ugslmd
9:34:55 (ugslmd)
9:34:55 (ugslmd) EXTERNAL FILTERS are OFF
9:34:55 (lmgrd) ugslmd using TCP-port 65335
9:34:55 (ugslmd) OUT: "visview_base" rmancha@USBOU1-LRMANCH8
9:34:55 (ugslmd) SLOG: Statistics Log Frequency is 240 minute(s).
9:34:55 (ugslmd) SLOG: TS update poll interval is 600 seconds.
9:34:55 (ugslmd) SLOG: Activation borrow reclaim percentage is 0.
9:34:55 (ugslmd) (@ugslmd-SLOG@) ===============================================
9:34:55 (ugslmd) (@ugslmd-SLOG@) === Vendor Daemon ===
9:34:55 (ugslmd) (@ugslmd-SLOG@) Vendor daemon: ugslmd
9:34:55 (ugslmd) (@ugslmd-SLOG@) Start-Date: Sun Apr 14 2019 09:34:55 Mountain Daylight Time
9:34:55 (ugslmd) (@ugslmd-SLOG@) PID: 2044
9:34:55 (ugslmd) (@ugslmd-SLOG@) VD Version: v11.15.0.0 build 215548 x64_n6 ( build 215548 (ipv6))
9:34:55 (ugslmd) (@ugslmd-SLOG@) === Startup/Restart Info ===
9:34:55 (ugslmd) (@ugslmd-SLOG@) Options file used: None
9:34:55 (ugslmd) (@ugslmd-SLOG@) Is vendor daemon a CVD: No
9:34:55 (ugslmd) (@ugslmd-SLOG@) Is FlexNet Licensing Service installed and compatible: No
9:34:55 (ugslmd) (@ugslmd-SLOG@) FlexNet Licensing Service Version: -NA-
9:34:55 (ugslmd) (@ugslmd-SLOG@) Is TS accessed: No
9:34:55 (ugslmd) (@ugslmd-SLOG@) TS access time: -NA-
9:34:55 (ugslmd) (@ugslmd-SLOG@) Number of VD restarts since LS startup: 0
9:34:55 (ugslmd) (@ugslmd-SLOG@) === Network Info ===
9:34:55 (ugslmd) (@ugslmd-SLOG@) Listening port: 65335
9:34:55 (ugslmd) (@ugslmd-SLOG@) Daemon select timeout (in seconds): 1
9:34:55 (ugslmd) (@ugslmd-SLOG@) === Host Info ===
9:34:55 (ugslmd) (@ugslmd-SLOG@) Host used in license file: USBOU1-SVM01
9:34:55 (ugslmd) (@ugslmd-SLOG@) HostID node-locked in license file: COMPOSITE=852C9B74D07D
9:34:55 (ugslmd) (@ugslmd-SLOG@) HostID of the License Server: 005056ba08ce
9:34:55 (ugslmd) (@ugslmd-SLOG@) Running on Hypervisor: Unknown Hypervisor
9:38:19 (ugslmd) TCP_NODELAY NOT enabled
9:38:19 (ugslmd) OUT: "NX11110" svc_gtc_prod@USSTLECPPLMAP22
9:38:19 (ugslmd) OUT: "NX11110_gateway" svc_gtc_prod@USSTLECPPLMAP22
13:14:07 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
13:14:07 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
13:14:20 (ugslmd) OUT: "NX11110" mmitcdba@USBOU1-STC
13:14:20 (ugslmd) OUT: "NX11110_gateway" mmitcdba@USBOU1-STC
13:14:26 (ugslmd) OUT: "NX11110_assemblies" mmitcdba@USBOU1-STC
13:14:29 (ugslmd) OUT: "NX11110_drafting" mmitcdba@USBOU1-STC
13:14:46 (ugslmd) OUT: "NX11110_solid_modeling" mmitcdba@USBOU1-STC
13:14:48 (ugslmd) IN: "NX11110_assemblies" mmitcdba@USBOU1-STC
13:14:48 (ugslmd) IN: "NX11110_drafting" mmitcdba@USBOU1-STC
13:14:48 (ugslmd) IN: "NX11110_gateway" mmitcdba@USBOU1-STC
13:14:48 (ugslmd) IN: "NX11110_solid_modeling" mmitcdba@USBOU1-STC
13:14:48 (ugslmd) IN: "NX11110" mmitcdba@USBOU1-STC
13:34:59 (ugslmd) (@ugslmd-SLOG@) ===============================================
13:34:59 (ugslmd) (@ugslmd-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
13:34:59 (ugslmd) (@ugslmd-SLOG@) Time: Sun Apr 14 2019 13:34:59 Mountain Daylight Time
13:34:59 (ugslmd) (@ugslmd-SLOG@) Request processing time, when, #concurrent clients, (private bytes (in KB)), client info (user, node, FD)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000000 ms at Sun Apr 14 2019 13:33:19 Mountain Daylight Time,#3,(5360K),(svc_gtc_prod,USSTLECPPLMAP22,456)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000000 ms at Sun Apr 14 2019 13:30:01 Mountain Daylight Time,#4,(5280K),(mmitcdba,USBOU1-SVM01,632)
13:34:59 (ugslmd) (@ugslmd-SLOG@) === Top 10 Peak Client Requests Processing Time (in ms) ===
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 09:40:01 Mountain Daylight Time,#4,(5352K),(mmitcdba,USBOU1-SVM01,492)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 10:00:00 Mountain Daylight Time,#4,(5280K),(mmitcdba,USBOU1-SVM01,632)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 10:00:01 Mountain Daylight Time,#4,(5280K),(mmitcdba,USBOU1-SVM01,632)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 10:50:00 Mountain Daylight Time,#4,(5356K),(mmitcdba,USBOU1-SVM01,492)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 11:00:00 Mountain Daylight Time,#4,(5360K),(mmitcdba,USBOU1-SVM01,492)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 11:20:00 Mountain Daylight Time,#4,(5356K),(mmitcdba,USBOU1-SVM01,492)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 11:30:00 Mountain Daylight Time,#4,(5360K),(mmitcdba,USBOU1-SVM01,492)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 11:40:00 Mountain Daylight Time,#4,(5360K),(mmitcdba,USBOU1-SVM01,492)
13:34:59 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 12:00:00 Mountain Daylight Time,#4,(5356K),(mmitcdba,USBOU1-SVM01,324)
13:34:59 (ugslmd) (@ugslmd-SLOG@) === Top 10 Peak In-house Operations time (in ms) ===
13:34:59 (ugslmd) (@ugslmd-SLOG@) NOTE: Peak times greater than 4 seconds get recorded.
13:34:59 (ugslmd) (@ugslmd-SLOG@) In-house operation time, when, #concurrent clients
13:34:59 (ugslmd) (@ugslmd-SLOG@) === Active Connections Info ===
13:34:59 (ugslmd) (@ugslmd-SLOG@) Peak active connections #5 attempted at Sun Apr 14 2019 13:14:38 Mountain Daylight Time
13:34:59 (ugslmd) (@ugslmd-SLOG@) === Memory Usage Info ===
13:34:59 (ugslmd) (@ugslmd-SLOG@) Peak private bytes 5384K attempted at Sun Apr 14 2019 09:40:01 Mountain Daylight Time
14:26:04 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:26:04 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:26:10 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:26:11 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:26:27 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:26:27 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:26:43 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:26:43 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:27:10 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:27:10 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
14:27:18 (ugslmd) OUT: "NX11110" mmitcdba@USBOU1-STC
14:27:18 (ugslmd) OUT: "NX11110_gateway" mmitcdba@USBOU1-STC
14:27:25 (ugslmd) OUT: "NX11110_assemblies" mmitcdba@USBOU1-STC
14:27:27 (ugslmd) OUT: "NX11110_drafting" mmitcdba@USBOU1-STC
14:27:29 (ugslmd) OUT: "NX11110_solid_modeling" mmitcdba@USBOU1-STC
14:27:35 (ugslmd) IN: "NX11110_assemblies" mmitcdba@USBOU1-STC
14:27:35 (ugslmd) IN: "NX11110_drafting" mmitcdba@USBOU1-STC
14:27:35 (ugslmd) IN: "NX11110_gateway" mmitcdba@USBOU1-STC
14:27:35 (ugslmd) IN: "NX11110_solid_modeling" mmitcdba@USBOU1-STC
14:27:35 (ugslmd) IN: "NX11110" mmitcdba@USBOU1-STC
15:34:54 (lmgrd) TIMESTAMP 4/14/2019
15:39:59 (ugslmd) TIMESTAMP 4/14/2019
17:35:00 (ugslmd) (@ugslmd-SLOG@) ===============================================
17:35:00 (ugslmd) (@ugslmd-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
17:35:00 (ugslmd) (@ugslmd-SLOG@) Time: Sun Apr 14 2019 17:35:00 Mountain Daylight Time
17:35:00 (ugslmd) (@ugslmd-SLOG@) Request processing time, when, #concurrent clients, (private bytes (in KB)), client info (user, node, FD)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000000 ms at Sun Apr 14 2019 17:33:20 Mountain Daylight Time,#3,(5280K),(svc_gtc_prod,USSTLECPPLMAP22,456)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000000 ms at Sun Apr 14 2019 17:30:01 Mountain Daylight Time,#4,(5280K),(mmitcdba,USBOU1-SVM01,632)
17:35:00 (ugslmd) (@ugslmd-SLOG@) === Top 10 Peak Client Requests Processing Time (in ms) ===
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 09:40:01 Mountain Daylight Time,#4,(5352K),(mmitcdba,USBOU1-SVM01,492)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 10:00:00 Mountain Daylight Time,#4,(5280K),(mmitcdba,USBOU1-SVM01,632)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 10:00:01 Mountain Daylight Time,#4,(5280K),(mmitcdba,USBOU1-SVM01,632)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 10:50:00 Mountain Daylight Time,#4,(5356K),(mmitcdba,USBOU1-SVM01,492)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 11:00:00 Mountain Daylight Time,#4,(5360K),(mmitcdba,USBOU1-SVM01,492)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 11:20:00 Mountain Daylight Time,#4,(5356K),(mmitcdba,USBOU1-SVM01,492)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 11:30:00 Mountain Daylight Time,#4,(5360K),(mmitcdba,USBOU1-SVM01,492)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 11:40:00 Mountain Daylight Time,#4,(5360K),(mmitcdba,USBOU1-SVM01,492)
17:35:00 (ugslmd) (@ugslmd-SLOG@) 00000016 ms at Sun Apr 14 2019 12:00:00 Mountain Daylight Time,#4,(5356K),(mmitcdba,USBOU1-SVM01,324)
17:35:00 (ugslmd) (@ugslmd-SLOG@) === Top 10 Peak In-house Operations time (in ms) ===
17:35:00 (ugslmd) (@ugslmd-SLOG@) NOTE: Peak times greater than 4 seconds get recorded.
17:35:00 (ugslmd) (@ugslmd-SLOG@) In-house operation time, when, #concurrent clients
17:35:00 (ugslmd) (@ugslmd-SLOG@) === Active Connections Info ===
17:35:00 (ugslmd) (@ugslmd-SLOG@) Peak active connections #5 attempted at Sun Apr 14 2019 13:14:38 Mountain Daylight Time
17:35:00 (ugslmd) (@ugslmd-SLOG@) === Memory Usage Info ===
17:35:00 (ugslmd) (@ugslmd-SLOG@) Peak private bytes 5384K attempted at Sun Apr 14 2019 09:40:01 Mountain Daylight Time
18:14:02 (ugslmd) OUT: "NX11110" ZhenlongZL.wang@CNNKG-WGQ5NTP2
18:14:02 (ugslmd) OUT: "NX11110_gateway" ZhenlongZL.wang@CNNKG-WGQ5NTP2
18:16:40 (ugslmd) OUT: "NX11110" Jianlin.Zhang@CNNKG-W1TVZR62
18:16:40 (ugslmd) OUT: "NX11110_gateway" Jianlin.Zhang@CNNKG-W1TVZR62
18:17:27 (ugslmd) UNSUPPORTED: "NX11110_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:17:27 (ugslmd) UNSUPPORTED: "MA_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:17:27 (ugslmd) UNSUPPORTED: "geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:17:37 (ugslmd) UNSUPPORTED: "NX11110_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:17:37 (ugslmd) UNSUPPORTED: "MA_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:17:38 (ugslmd) UNSUPPORTED: "geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:22:34 (ugslmd) UNSUPPORTED: "NX11110_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:22:34 (ugslmd) UNSUPPORTED: "MA_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:22:34 (ugslmd) UNSUPPORTED: "geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:22:59 (ugslmd) UNSUPPORTED: "NX11110_mechanisms" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:23:00 (ugslmd) OUT: "mechanisms" Jianlin.Zhang@CNNKG-W1TVZR62
18:23:11 (ugslmd) UNSUPPORTED: "NX11110_nx_ftk" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:23:11 (ugslmd) OUT: "nx_ftk" Jianlin.Zhang@CNNKG-W1TVZR62
18:24:49 (ugslmd) IN: "mechanisms" Jianlin.Zhang@CNNKG-W1TVZR62
18:24:50 (ugslmd) OUT: "NX11110_solid_modeling" Jianlin.Zhang@CNNKG-W1TVZR62
18:24:51 (ugslmd) IN: "nx_ftk" Jianlin.Zhang@CNNKG-W1TVZR62
18:28:06 (ugslmd) OUT: "NX11110" Sufen.Qi@CNNKG-W7NLCB3X
18:28:06 (ugslmd) OUT: "NX11110_gateway" Sufen.Qi@CNNKG-W7NLCB3X
18:28:23 (ugslmd) OUT: "NX11110" dechao.du@CNNKG-WCDYTKY1
18:28:23 (ugslmd) OUT: "NX11110_gateway" dechao.du@CNNKG-WCDYTKY1
18:29:33 (ugslmd) IN: "NX11110" Sufen.Qi@CNNKG-W7NLCB3X
18:29:33 (ugslmd) IN: "NX11110_gateway" Sufen.Qi@CNNKG-W7NLCB3X
18:31:35 (ugslmd) OUT: "NX11110_solid_modeling" dechao.du@CNNKG-WCDYTKY1
18:33:00 (ugslmd) OUT: "NX11110_solid_modeling" Sufen.Qi@CNNKG-W7NLCB3X
18:33:32 (ugslmd) OUT: "NX11110" Sufen.Qi@CNNKG-W7NLCB3X
18:33:32 (ugslmd) OUT: "NX11110_gateway" Sufen.Qi@CNNKG-W7NLCB3X
18:36:44 (ugslmd) IN: "NX11110" Sufen.Qi@CNNKG-W7NLCB3X
18:36:44 (ugslmd) IN: "NX11110_gateway" Sufen.Qi@CNNKG-W7NLCB3X
18:37:42 (ugslmd) UNSUPPORTED: "NX11110_nx_point_cloud_view" (PORT_AT_HOST_PLUS ) dechao.du@CNNKG-WCDYTKY1 (No such feature exists. (-5,346))
18:37:42 (ugslmd) UNSUPPORTED: "nx_point_cloud_view" (PORT_AT_HOST_PLUS ) dechao.du@CNNKG-WCDYTKY1 (No such feature exists. (-5,346))
18:38:52 (ugslmd) OUT: "NX11110_solid_modeling" ZhenlongZL.wang@CNNKG-WGQ5NTP2
18:39:11 (ugslmd) OUT: "NX11110_assemblies" ZhenlongZL.wang@CNNKG-WGQ5NTP2
18:43:04 (ugslmd) IN: "NX11110_solid_modeling" ZhenlongZL.wang@CNNKG-WGQ5NTP2
18:43:04 (ugslmd) OUT: "NX11110_drafting" ZhenlongZL.wang@CNNKG-WGQ5NTP2
18:54:34 (ugslmd) OUT: "NX11110" Jianlin.Zhang@CNNKG-W1TVZR62
18:54:34 (ugslmd) OUT: "NX11110_gateway" Jianlin.Zhang@CNNKG-W1TVZR62
18:54:46 (ugslmd) UNSUPPORTED: "NX11110_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:54:46 (ugslmd) UNSUPPORTED: "MA_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:54:46 (ugslmd) UNSUPPORTED: "geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:54:47 (ugslmd) UNSUPPORTED: "NX11110_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:54:47 (ugslmd) UNSUPPORTED: "MA_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:54:47 (ugslmd) UNSUPPORTED: "geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:55:15 (ugslmd) OUT: "NX11110_step_ap203" Jianlin.Zhang@CNNKG-W1TVZR62
18:55:21 (ugslmd) UNSUPPORTED: "NX11110_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:55:21 (ugslmd) UNSUPPORTED: "MA_geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:55:21 (ugslmd) UNSUPPORTED: "geometric_tol" (PORT_AT_HOST_PLUS ) Jianlin.Zhang@CNNKG-W1TVZR62 (No such feature exists. (-5,346))
18:55:22 (ugslmd) OUT: "NX11110_solid_modeling" Jianlin.Zhang@CNNKG-W1TVZR62
18:55:59 (ugslmd) IN: "NX11110_step_ap203" Jianlin.Zhang@CNNKG-W1TVZR62
18:56:01 (ugslmd) IN: "NX11110_solid_modeling" Sufen.Qi@CNNKG-W7NLCB3X
18:56:13 (ugslmd) OUT: "NX11110_solid_modeling" Sufen.Qi@CNNKG-W7NLCB3X
19:00:30 (ugslmd) IN: "NX11110_solid_modeling" Sufen.Qi@CNNKG-W7NLCB3X
19:03:07 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
19:03:07 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
19:03:10 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
19:03:10 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
19:03:50 (ugslmd) UNSUPPORTED: "NX11110_teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
19:03:50 (ugslmd) UNSUPPORTED: "teamcenter_author" (PORT_AT_HOST_PLUS ) mmitcdba@TcServer (No such feature exists. (-5,346))
19:04:00 (ugslmd) OUT: "NX11110_solid_modeling" Sufen.Qi@CNNKG-W7NLCB3X
19:04:08 (ugslmd) OUT: "NX11110" mmitcdba@USBOU1-STC
19:04:08 (ugslmd) OUT: "NX11110_gateway" mmitcdba@USBOU1-STC
19:04:18 (ugslmd) OUT: "NX11110_assemblies" mmitcdba@USBOU1-STC
19:04:22 (ugslmd) OUT: "NX11110_drafting" mmitcdba@USBOU1-STC
19:05:17 (ugslmd) OUT: "NX11110_solid_modeling" mmitcdba@USBOU1-STC
19:05:30 (ugslmd) IN: "NX11110_assemblies" mmitcdba@USBOU1-STC
19:05:30 (ugslmd) IN: "NX11110_drafting" mmitcdba@USBOU1-STC
19:05:30 (ugslmd) IN: "NX11110_gateway" mmitcdba@USBOU1-STC
19:05:30 (ugslmd) IN: "NX11110_solid_modeling" mmitcdba@USBOU1-STC
19:05:30 (ugslmd) IN: "NX11110" mmitcdba@USBOU1-STC
19:10:20 (ugslmd) IN: "NX11110_solid_modeling" Sufen.Qi@CNNKG-W7NLCB3X
19:11:21 (ugslmd) OUT: "NX11110_solid_modeling" Sufen.Qi@CNNKG-W7NLCB3X
19:12:35 (ugslmd) IN: "NX11110_assemblies" ZhenlongZL.wang@CNNKG-WGQ5NTP2
19:14:43 (ugslmd) IN: "NX11110_drafting" ZhenlongZL.wang@CNNKG-WGQ5NTP2
19:14:43 (ugslmd) OUT: "NX11110_solid_modeling" ZhenlongZL.wang@CNNKG-WGQ5NTP2
19:14:55 (ugslmd) IN: "NX11110_solid_modeling" ZhenlongZL.wang@CNNKG-WGQ5NTP2
19:15:15 (ugslmd) OUT: "NX11110_solid_modeling" ZhenlongZL.wang@CNNKG-WGQ5NTP2
19:17:58 (ugslmd) IN: "NX11110_solid_modeling" dechao.du@CNNKG-WCDYTKY1
19:23:59 (ugslmd) OUT: "NX11110" Yuki.Wang@CNNKG-WGQ6MLP2
19:23:59 (ugslmd) OUT: "NX11110_gateway" Yuki.Wang@CNNKG-WGQ6MLP2
19:24:18 (ugslmd) OUT: "NX11110_solid_modeling" Yuki.Wang@CNNKG-WGQ6MLP2
19:25:51 (ugslmd) OUT: "NX11110" Walt.Jiang@CNNKG-WGQ5MTP2
19:25:51 (ugslmd) OUT: "NX11110_gateway" Walt.Jiang@CNNKG-WGQ5MTP2
19:25:54 (ugslmd) IN: "NX11110" Sufen.Qi@CNNKG-W7NLCB3X
19:25:54 (ugslmd) IN: "NX11110_gateway" Sufen.Qi@CNNKG-W7NLCB3X
19:25:54 (ugslmd) IN: "NX11110_solid_modeling" Sufen.Qi@CNNKG-W7NLCB3X
19:27:15 (ugslmd) OUT: "NX11110" Sufen.Qi@CNNKG-W7NLCB3X
19:27:15 (ugslmd) OUT: "NX11110_gateway" Sufen.Qi@CNNKG-W7NLCB3X
19:27:52 (ugslmd) IN: "NX11110_solid_modeling" Yuki.Wang@CNNKG-WGQ6MLP2
19:27:53 (ugslmd) OUT: "NX11110_drafting" Yuki.Wang@CNNKG-WGQ6MLP2
19:28:41 (ugslmd) IN: "NX11110" Sufen.Qi@CNNKG-W7NLCB3X
19:28:41 (ugslmd) IN: "NX11110_gateway" Sufen.Qi@CNNKG-W7NLCB3X
19:28:45 (ugslmd) IN: "NX11110" Sufen.Qi@CNNKG-W7NLCB3X
19:28:45 (ugslmd) IN: "NX11110_gateway" Sufen.Qi@CNNKG-W7NLCB3X
Siemens Genius
Contact GTAC with your Webkey (Sold-to ID) to generate correct license file.
Best regards,
Siemens Genius
@MilaWeitz I think you are right: it looks there is no teamcenter_author license available
Paolo
