The FSC is not responding. Start the FSC Error:The configured v100 encryption key is the default key
Hello all,
Not able to install teamcenter whose version is (Tc11.2.0a_win64) . The error during installation says "The FSC is not responding. Start the FSC and click OK to continue"
Also FSC_HOME or FMS_HOME environment variables need not be set prior to Teamcenter installation. Please correct me if am wrong here..
Below is the stact trace from FSCID_fsc.log file from the TC_ROOT/fsc
INFO - 2018/02/14-10:31:17,050 UTC - LAPTOP-XXXXXXXX - Whole File Cache shutdown.
INFO - 2018/02/14-10:31:17,050 UTC - LAPTOP-XXXXXXXX - Read Fast Cache shutdown.
INFO - 2018/02/14-10:31:17,051 UTC - LAPTOP-XXXXXXXX - Write Fast Cache shutdown.
INFO - 2018/02/14-10:31:21,664 UTC - LAPTOP-XXXXXXXX - FMSServerCache starting...
INFO - 2018/02/14-10:31:21,664 UTC - LAPTOP-XXXXXXXX - FMSServerCache version: 11.1, build date: 20150712
INFO - 2018/02/14-10:31:21,665 UTC - LAPTOP-XXXXXXXX - FMSUtil version: 11.1, build date: 20150712
INFO - 2018/02/14-10:31:21,665 UTC - LAPTOP-XXXXXXXX - FSCJavaClientProxy version: 11.1, build date: 20150712
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.vm.version: 25.144-b01
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.vm.vendor: Oracle Corporation
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.vm.info: mixed mode
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.io.tmpdir: C:\Users\#####~1\AppData\Local\Temp\
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - java.library.path: D:\Siemens\Teamcenter11\fsc/lib
INFO - 2018/02/14-10:31:21,666 UTC - LAPTOP-XXXXXXXX - file.encoding: Cp1252
INFO - 2018/02/14-10:31:21,672 UTC - LAPTOP-XXXXXXXX - line.separator: CRLF
INFO - 2018/02/14-10:31:21,672 UTC - LAPTOP-XXXXXXXX - user.name: #####
INFO - 2018/02/14-10:31:21,672 UTC - LAPTOP-XXXXXXXX - user.home: C:\Users\#####
INFO - 2018/02/14-10:31:21,672 UTC - LAPTOP-XXXXXXXX - user.dir: D:\Siemens\Teamcenter11\fsc
INFO - 2018/02/14-10:31:21,949 UTC - LAPTOP-XXXXXXXX - ********************************************************************
INFO - 2018/02/14-10:31:21,949 UTC - LAPTOP-XXXXXXXX - Master FSC Path = fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:31:21,949 UTC - LAPTOP-XXXXXXXX - Local FSCId = FSC_Prol
INFO - 2018/02/14-10:31:21,949 UTC - LAPTOP-XXXXXXXX - Local enterpriseId = 0
INFO - 2018/02/14-10:31:21,956 UTC - LAPTOP-XXXXXXXX - FSC Configuration master path: fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:31:21,957 UTC - LAPTOP-XXXXXXXX - FSC Configuration local path: FSC_Prol.xml
INFO - 2018/02/14-10:31:21,957 UTC - LAPTOP-XXXXXXXX - FSC configuration is complete using a locally served FMS master configuration file.
INFO - 2018/02/14-10:31:21,957 UTC - LAPTOP-XXXXXXXX - Configuration backup file already exists: D:\Siemens\Teamcenter11\fsc/confighistory/0-021089d55ef80b74a8e58ce3250d8e11-fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:31:21,957 UTC - LAPTOP-XXXXXXXX - Located configuration for FSC: 'FSC_Prol'
ERROR - 2018/02/14-10:31:21,974 UTC - LAPTOP-XXXXXXXX - The configured v100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:424) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/14-10:31:21,975 UTC - LAPTOP-XXXXXXXX - The configured F100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:431) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/14-10:31:21,975 UTC - LAPTOP-XXXXXXXX - The configured M050 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:438) com.teamcenter.fms.servercache.FMSServerCache
WARN - 2018/02/14-10:31:21,976 UTC - LAPTOP-XXXXXXXX - The fscadmin command 'filestoredetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
WARN - 2018/02/14-10:31:21,976 UTC - LAPTOP-XXXXXXXX - The fscadmin command 'cachedetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
INFO - 2018/02/14-10:31:21,987 UTC - LAPTOP-XXXXXXXX - Read Fast Cache initialized at: C:\Users\#####/FSCCache/FSC_Prol/read
INFO - 2018/02/14-10:31:21,987 UTC - LAPTOP-XXXXXXXX - Read Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2018/02/14-10:31:21,996 UTC - LAPTOP-XXXXXXXX - Write Fast Cache initialized at: C:\Users\#####/FSCCache/FSC_Prol/write
INFO - 2018/02/14-10:31:21,996 UTC - LAPTOP-XXXXXXXX - Write Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2018/02/14-10:31:22,002 UTC - LAPTOP-XXXXXXXX - Whole File Cache disabled at: C:\Users\#####\FSCCache
INFO - 2018/02/14-10:31:22,002 UTC - LAPTOP-XXXXXXXX - Whole File Cache parameter values: filespersubdir=0,maxfileage=(3650/30),percentfree=30,purgewait=(0/30),purgecycle=(240/30),partitions=(1/0)
INFO - 2018/02/14-10:31:22,069 UTC - LAPTOP-XXXXXXXX - LogLevel set to WARN
INFO - 2018/02/14-10:31:22,238 UTC - LAPTOP-XXXXXXXX - Server Initialization successful, server is started.
INFO - 2018/02/14-10:32:00,134 UTC - LAPTOP-XXXXXXXX - Whole File Cache shutdown.
INFO - 2018/02/14-10:32:00,136 UTC - LAPTOP-XXXXXXXX - Read Fast Cache shutdown.
INFO - 2018/02/14-10:32:00,137 UTC - LAPTOP-XXXXXXXX - Write Fast Cache shutdown.
INFO - 2018/02/14-10:32:02,827 UTC - LAPTOP-XXXXXXXX - FMSServerCache starting...
INFO - 2018/02/14-10:32:02,828 UTC - LAPTOP-XXXXXXXX - FMSServerCache version: 11.1, build date: 20150712
INFO - 2018/02/14-10:32:02,828 UTC - LAPTOP-XXXXXXXX - FMSUtil version: 11.1, build date: 20150712
INFO - 2018/02/14-10:32:02,829 UTC - LAPTOP-XXXXXXXX - FSCJavaClientProxy version: 11.1, build date: 20150712
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.vm.version: 25.144-b01
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.vm.vendor: Oracle Corporation
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.vm.info: mixed mode
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.io.tmpdir: C:\Users\#####~1\AppData\Local\Temp\
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - java.library.path: D:\Siemens\Teamcenter11\fsc/lib
INFO - 2018/02/14-10:32:02,830 UTC - LAPTOP-XXXXXXXX - file.encoding: Cp1252
INFO - 2018/02/14-10:32:02,838 UTC - LAPTOP-XXXXXXXX - line.separator: CRLF
INFO - 2018/02/14-10:32:02,838 UTC - LAPTOP-XXXXXXXX - user.name: #####
INFO - 2018/02/14-10:32:02,838 UTC - LAPTOP-XXXXXXXX - user.home: C:\Users\#####
INFO - 2018/02/14-10:32:02,839 UTC - LAPTOP-XXXXXXXX - user.dir: D:\Siemens\Teamcenter11\fsc
INFO - 2018/02/14-10:32:03,076 UTC - LAPTOP-XXXXXXXX - ********************************************************************
INFO - 2018/02/14-10:32:03,077 UTC - LAPTOP-XXXXXXXX - Master FSC Path = fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:32:03,077 UTC - LAPTOP-XXXXXXXX - Local FSCId = FSC_Prol
INFO - 2018/02/14-10:32:03,077 UTC - LAPTOP-XXXXXXXX - Local enterpriseId = 0
INFO - 2018/02/14-10:32:03,077 UTC - LAPTOP-XXXXXXXX - ********************************************************************
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - FSC Configuration master path: fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - FSC Configuration local path: FSC_Prol.xml
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - FSC configuration is complete using a locally served FMS master configuration file.
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - Configuration backup file already exists: D:\Siemens\Teamcenter11\fsc/confighistory/0-021089d55ef80b74a8e58ce3250d8e11-fmsmaster_FSC_Prol.xml
INFO - 2018/02/14-10:32:03,082 UTC - LAPTOP-XXXXXXXX - Located configuration for FSC: 'FSC_Prol'
ERROR - 2018/02/14-10:32:03,095 UTC - LAPTOP-XXXXXXXX - The configured v100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:424) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/14-10:32:03,096 UTC - LAPTOP-XXXXXXXX - The configured F100 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:431) com.teamcenter.fms.servercache.FMSServerCache
ERROR - 2018/02/14-10:32:03,096 UTC - LAPTOP-XXXXXXXX - The configured M050 encryption key is the default key:com.teamcenter.fms.servercache.FMSServerCache.initTicketingAndEncryption(FMSServerCache.java:438) com.teamcenter.fms.servercache.FMSServerCache
WARN - 2018/02/14-10:32:03,096 UTC - LAPTOP-XXXXXXXX - The fscadmin command 'filestoredetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
WARN - 2018/02/14-10:32:03,096 UTC - LAPTOP-XXXXXXXX - The fscadmin command 'cachedetail' can be run from any fscadmin client. 'fscadminpolicies' in the fmsmaster configuration can be used to prevent this.
INFO - 2018/02/14-10:32:03,105 UTC - LAPTOP-XXXXXXXX - Read Fast Cache initialized at: C:\Users\#####/FSCCache/FSC_Prol/read
INFO - 2018/02/14-10:32:03,106 UTC - LAPTOP-XXXXXXXX - Read Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2018/02/14-10:32:03,179 UTC - LAPTOP-XXXXXXXX - Write Fast Cache initialized at: C:\Users\#####/FSCCache/FSC_Prol/write
INFO - 2018/02/14-10:32:03,180 UTC - LAPTOP-XXXXXXXX - Write Fast Cache parameter values: mfp=512,ms=623,hp=32,me=0,memb=16
INFO - 2018/02/14-10:32:03,191 UTC - LAPTOP-XXXXXXXX - Whole File Cache disabled at: C:\Users\#####\FSCCache
INFO - 2018/02/14-10:32:03,191 UTC - LAPTOP-XXXXXXXX - Whole File Cache parameter values: filespersubdir=0,maxfileage=(3650/30),percentfree=30,purgewait=(0/30),purgecycle=(240/30),partitions=(1/0)
INFO - 2018/02/14-10:32:03,260 UTC - LAPTOP-XXXXXXXX - LogLevel set to WARN
INFO - 2018/02/14-10:32:03,418 UTC - LAPTOP-XXXXXXXX - Server Initialization successful, server is started.
Kindly help me out with this.
Thanks in advance..
Re: The FSC is not responding. Start the FSC Error:The configured v100 encryption key is the default
@UmeshProlim wrote:
Hello all,
Thanks in advance..
what is the issue you are facing? The encryption issue comes by default ..can be ignored. do you see your fsc service running in windows/Unix?
