The error while installing ofTC
When I install the TC on client side, I got one error saying that "Database cannot be initialized".
To fix this error, I did create new instance and create new DB. But it was not working.
Also I ccreate .sql file correctly.
Do you have any idea?
Re: The error while installing ofTC
Your question doesn't make sense. Databases are not installed on the client. You'll have to provide more information, screen shots or syslogs to help us understand your issue and offer advice.
Evaluating: AW 3.4
Thank you for youre reply.
I will check this poit with my friend and I will post my questions then again.
