Tooling Library Installation Wizard
Hi all ,
Have you ever used the Tooling Library Installation Wizard to use the MoldWizard parts in the integration of TC - NX ?
As you know , you can use the Mold Wizard feature in native NX to create automatically mold base according to the catalog standart informations such as Hasko etc . When i was trying to use it i fill all the required values but i'm getting an error message ? I could not find the missing point. Could you help me please ?
Best Regards
Gurkan
Re: Tooling Library Installation Wizard
Hi all ,
After Java upgrading (1.7 to 1.8) the problem is solved.
Best Regards
Gurkan
