Total List of Teamcenter ITK API documentation
I looked through the GTAC documentation and I don't find a document that simply lists all possible Teamcenter ITK API.
Whereby,  the API call is listed with input and output parameters,  and an explanation of each parameter(i.e. data type, etc.. )
Anyone aware of such a document or a way to produce a list of all possible Teamcenter ITK API calls ?
Roy
4 REPLIES 4
Re: Total List of Teamcenter ITK API documentation
Good afternoon, as far as I know this should be located in TcXX.X.X_pub.zip, which you can download from GTAC inside this archive find the archive tcversion_en_US_tcrefs_webServer.zip Teamcenter developer references
Siemens Legend Siemens Legend
Siemens Legend
does that help?
https://support.industrysoftware.automation.siemens.com/docs/teamcenter/ --> Teamcenter 12.1 References for Administrators and Customizers --> Integration Toolkit (ITK) Function Reference
Thank you. That is what I was looking for.
Thanks !   This is very helpful.
