Translate UGPART to pdf or tiff with dispatcher
I have Teamcenter 11.3 installed with dispatcher .
How can i use the TCRS translator called nxtopdf or nxtotiff into my setup?
Thank you.
7 REPLIES 7
Re: Translate UGPART to pdf or tiff with dispatcher
Any ideas?
Thank you.
I use Workflow to create NX to PDF files.
Larry Carpenter, P.E.
Hello Larry,
Which service are you calling in the workflow?
Thank you
I fixed my issue using nxtocgm translator with -pdf no cgm arguments.
I currently use nxtopdfdirect through a workflow
TSTK-CreateTranslationRequest
-ProviderName : SIEMENS
-ServiceName : nxtopdfdirect
-Priority : 1
-DatasetTypeName : UGPART
This works fine. I want to be able to get dispatcher to run this when a user saves and uploads in teamcenter / NX so that dispatcher creates / updates the pdf in the Item Revision.
Any ideas?
Hi Tom,
I didnt find anu service called 'nxtopdfdirect'. is this OOTB service or custom?
I use a WF handler to export the data to the OS and run the NX2PDF command line utility.
