Re: TsFtsIndexer fails to run first time
@Lumi
attach your configuration.xml file for slor installation.
Hello JFK1963,
We've installed Indexing Engine on separate server.
Please refer below for config.xml as I'm unable to attach here.
<?xml version="1.0" encoding="UTF-8"?>
<root>
<tem engine="2008.0.0" />
<settings>
<sourceDir value="D:\\Dump\\Tc11.2.0a_win64_Merged" />
<application value="tceng" />
<installLanguage value="ENGLISH" />
<silentMaintenance value="false" />
<pluginsVersion value="60_20181019.00" />
<aboutFullVersion value="11.4.0.10" />
<installingUser value="tcadmin" />
<installDir value="D:\\Apps\\TC11.4\\Teamcenter11" />
<addRemoveEntry value="HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\Teamcenter11-180822011153" />
<version value="11000.2.5.60" />
</settings>
<config name="Philips Lumileds QA Database" id="LumiledsQA">
<comments />
<data>
<flexClient guid="7221ECFBC9555CDF997FC3F575022761">
<nX5Port value="28000" />
<port value="27000" />
<nX4String value="" />
<nX5Host value="SGGSINTSYSVW192" />
<host value="SGGSINTSYSVW192" />
<envServerString value="28000@SGGSINTSYSVW192" />
<nX5CheckBox value="true" />
<nX5String value="28000@SGGSINTSYSVW192" />
</flexClient>
<CharacterEncoding guid="5DC9A91F385448965CD1EDE3200A15E9">
<charEncoding value="Cp1252" />
</CharacterEncoding>
<security guid="ZUG63OE2YRNFD1VY13KCEZM52XFJP45D">
<adminDirectory value="D:\\Apps\\TC11.4\\Teamcenter11\\security" />
</security>
<adminUser guid="2E53CFC3AC75665E50FF0F207D1D013B">
<credentials value="-u=infodba -pf=D:\\Apps\\TC11.4\\Teamcenter11\\security\\LumiledsQA_infodba.pwf -g=dba" />
<user value="infodba" />
<pwf value="D:\\Apps\\TC11.4\\Teamcenter11\\security\\LumiledsQA_infodba.pwf" />
</adminUser>
<FSCMasterSettings guid="EBC3422F77C6BF18FE0E3A821EFE1134">
<masterModel value="Simple Model" />
</FSCMasterSettings>
<volume guid="1F16971107DE44C0C7827F800EE4AEF8">
<hostName value="SGGSINTSYSVW192" />
<fscId value="FSC_SGGSINTSYSVW192_tcadmin" />
<port value="4544" />
<fscModel value="Simple Model" />
<name value="dba" />
<location value="E:\\Data\\Teamcenter\\tcvols\\QA\\dba" />
</volume>
<transientVolume guid="983980098FF188A8C4BF08E8168A32A8">
<windowsVolume value="C:\\Temp\\transientVolume_PHILIPS_QA" />
<unixVolume value="/tmp/transientVolume_PHILIPS_QA" />
</transientVolume>
<RACSettings guid="5556237F3F54D1DD059F0A385B88CA46">
<tempFolder value="" />
<browserLoc value="" />
</RACSettings>
<RACFCCSettings guid="8BC34CE71B738026DF2B3D94A83A836C">
<buildTccs value="false" />
<doMerge value="true" />
<newHome value="D:\\Apps\\TC11.4\\Teamcenter11\\tccs" />
<existingHome value="D:\\Apps\\TC11.4\\Teamcenter11\\tccs" />
<needToSetFmsHome value="true" />
</RACFCCSettings>
<TcOracleEngine guid="F4F7C0852B27D6E56B8C64BE77FFA14C">
<populate value="true" />
<flush value="false" />
<port value="51521" />
<service value="OAPH016A" />
<host value="130.147.68.132" />
<create value="false" />
<createUser value="false" />
<user value="PHILIPS" />
<uTF8Enabled value="false" />
</TcOracleEngine>
<DSMSettings guid="OHGTNALQO1DW9T12L5NEG4V1H81YJRZ7">
<keyLocation value="" />
</DSMSettings>
<SsoRc guid="E55610E8ECDB81520D8DAFD99D6BF542">
<tssBrowser value="" />
<loginURL value="" />
<appId value="Teamcenter" />
</SsoRc>
<FSCParents guid="30E3AC7AF5CA4F82EAE21C80737EE55B">
<assignmentMode value="clientmap" />
<parents value="http,SGGSINTSYSVW192,4544,,0,lan,;" />
</FSCParents>
<FSCService guid="F2FCBCEC03DFF7F9D1E3A11EC9B64BD2">
<addToBootstrap value="true" />
<log value="" />
<fscReadCacheDir value="$HOME\\FSCCache" />
<fscWriteCacheDir value="$HOME\\FSCCache" />
<fscReadCacheSize value="10" />
<fscWriteCacheSize value="10" />
<serverID value="FSC_SGGSINTSYSVW192_tcadmin" />
</FSCService>
<OSUser guid="CA769D31FD7E122E5E509A0BBBD7E809">
<user value="SGGSINTSYSVW192\\tcadmin" />
</OSUser>
<FSCServiceFCCDefaults guid="7311DC5E94724BED0DD7419FCDE055CF">
<cacheDirWin value="$HOME\\FCCCache" />
<partialReadCacheSize value="3000" />
<readCacheSize value="1000" />
<cacheDirUnix value="/tmp/$USER/FCCCache" />
<writeCacheSize value="1000" />
</FSCServiceFCCDefaults>
<DefaultSiteWebServer guid="56F173AF29700F24775A415586BCBFC7">
<port value="8080" />
<appName value="tc" />
<host value="SGGSINTSYSVW188" />
</DefaultSiteWebServer>
<foundationSettings guid="LHBY67ZYMYHSKED26FHDNDHFJTZD84I7">
<updateDatabase value="true" />
<productionEnvironment value="true" />
<requestMetaCacheRebuild value="false" />
<genServCache value="" />
<genClientCache value="generate all" />
<enableGenServCache value="true" />
<templatesToBeInstalled value="" />
<quickClone value="false" />
</foundationSettings>
<RichClient2-tierSettings guid="FD83D83E316B865D4AFA06E24C106EC3">
<webServer value="" />
</RichClient2-tierSettings>
<FtsIndexingEngineUser guid="D107BE2FB3509E62F011DD94A774C40D">
<user value="solr_admin" />
</FtsIndexingEngineUser>
<AwsCorpServerSettings guid="4D5C7724D42E20C6B6889D2A564A4F85">
<awcUrl value="http://:7001/awc" />
<fourTierUrl value="http://:7001/tc" />
<useAdditionalSolrUrls value="false" />
<additionalUrls value="" />
<siteID value="-1865218271" />
<searchEngineUrl value="http://SGGSINTSYSVW192:8983/solr" />
</AwsCorpServerSettings>
<FSCServiceConnections guid="E4BDA0B521CB10A49F0CE123C9F326F1">
<connections value="http,4544,;" />
</FSCServiceConnections>
<FtsIndexerEngineComponent guid="BJ7WNBVI2TJDLPJYL81CWBYETUPDA0G6">
<solrJreLocation value="C:\\Program Files\\Java\\jre1.8.0_172" />
<updateSolrSchema value="true" />
<installAsService value="true" />
<solrSchemaFolderLocation value="D:\\Apps\\TC11.4\\TCDATA\\ftsi\\solr_schema_files" />
</FtsIndexerEngineComponent>
<IIOPServers guid="98BB5D37B60CA1D6818A87E53D6200C0">
<servers value="D:\\Apps\\TC11.4\\TCDATA,TcData," />
<activationMode value="PER_CLIENT" />
<connectPort value="1572" />
<configFolder value="D:\\Apps\\TC11.4\\Teamcenter11\\iiopservers" />
</IIOPServers>
<FscGroupSiteImport guid="F8C9E04EFFC31316E02CB4FE7D0EF96D">
<remoteGroupSites value="" />
</FscGroupSiteImport>
<FscSiteImport guid="630BECF927EC742A748A97486D5868DA">
<remoteSites value="" />
</FscSiteImport>
<RcFmsProxy guid="BCC19950F2972B881F669FEFA0019C06">
<httpPort value="" />
<httpHost value="" />
<httpsHost value="" />
<httpsPort value="" />
</RcFmsProxy>
<tcdata guid="4500621E2BE24BF0DD6ABF31EBA01088">
<path value="D:\\Apps\\TC11.4\\TCDATA" />
<serverHostLocation value="SGGSINTSYSVW192" />
<create value="true" />
<siteId value="-2093764680" />
<shareName value="" />
<dsmKeyPath value="" />
</tcdata>
<productExcellence guid="0YFDC18PY2QFNSBJW7SNDMUUWJWUMQEA">
<participate value="false" />
</productExcellence>
<ClientTransportMode guid="18DVF0VKAUEEFBQ5JOI6U7M17PHXK5XA">
<filterText value="" />
<useConfig value="false" />
</ClientTransportMode>
</data>
<features>
<installed feature="A0CF69C3A0BC61770EB81BD22667EA52" name="Microsoft Visual C++ Runtimes" />
<installed feature="90C2A1C96F6A61FAB397AF88ABE4AAC1" name="FMS Server Cache" />
<installed feature="8C061DD51E13E0CB9DC4687B1A3348BE" name="Teamcenter Foundation" />
<installed feature="15CB3E81DB098FE311D83EE78162E58D" name="Teamcenter Task Manager Service" />
<installed feature="37E395BDF9DB56B53B161BDF703E8DD5" name="Sample files" />
<installed feature="E9B8A3F6B7B53AE540DCC54C13B3C201" name="Change Management/Data Model" />
<installed feature="301F12B06B3EAAB18DC0C2B9444F3B20" name="Translation Service Database Module/Data Model" />
<installed feature="00C240CCAA28E298FC21893351BBD51A" name="Lumileds_phase1/Runtime Server" />
<installed feature="29259AB87A86CBBF3B42ACDBB39C0B31" name="Lumileds_phase1/Data Model" />
<installed feature="115EA2D072AE11E19424D3DD4724019B" name="Change and Schedule Management Interface/Runtime Server" />
<installed feature="D18192F4475ADEA11EC85F454C6ABA31" name="Change and Schedule Management Interface/Data Model" />
<installed feature="24E2685325021872095B1249CDE5B49B" name="Active Workspace/Runtime Server" />
<installed feature="EF6284519D32B8DADCF0F05213AF807B" name="Active Workspace/Data Model" />
<installed feature="6ZP7BHSD5WYX5ARPYQOLUEE9TWR8TKW3" name="Authorization Active Workspace/Runtime Server" />
<installed feature="E5F45EFFA34DA47F2CD8E4F150F81C11" name="Authorization Active Workspace/Data Model" />
<installed feature="B75C673EA57FD9D5EBEF544DE7F07F4E" name="Change Management for Active Workspace/Data Model" />
<installed feature="EAC1322926B2432183084D0F09AFEA25" name="Change Management for Active Workspace/Runtime Server" />
<installed feature="27E4C674808243A686ECAF3BE7EE9670" name="Workflow for Active Workspace" />
<installed feature="61QW5SNSWG3PQS38UCD2DKQQAOD9EIAL" name="Active Content Structure/Runtime Server" />
<installed feature="0F47FD6920230AC9CFDB79C9AC941ADA" name="Active Content Structure/Data Model" />
<installed feature="F198327D035C27E82A2E7C67A1971BA7" name="Active Workspace Indexing Engine" />
<spf feature="9B6D88C9694788E8F36E79F05AA763FD" name="Authorization Active Workspace" />
<spf feature="DFCD67D128B68E6961C46E080B24B42D" name="Change Management" />
<spf feature="47962310EB55BD6F854306C8173A1ECD" name="Lumileds_phase1" />
<spf feature="C1DB81C17CAA998C7CDD78DFFFA5890E" name="Active Content Structure" />
<spf feature="751BC8021BC6CA80EE1479BDEE3D72DA" name="Change and Schedule Management Interface" />
<spf feature="AE72829CDC1E0045DE5D97C2E69CFC92" name="Active Workspace" />
<spf feature="326CA27DCABEFBB96D2735397986C1B9" name="Translation Service Database Module" />
<spf feature="20DBEC420864E9576004CB43361AA902" name="Change Management for Active Workspace" />
</features>
</config>
<updateManager>
<patch dir="E:\\TC_Dump\\Tc11.4.0_patch_10_wntx64\\wntx64" backup="D:\\Apps\\TC11.4\\Teamcenter11\\install\\install\\patches\\backup" date="201812071815" version="11000.2.5.60" parentVersion="11.2" applicationId="Foundation" />
<patch dir="D:\\Dump\\Tc11.2.3_ActiveWorkspace4.0.3_wntx64\\wntx64" backup="D:\\Apps\\TC11.4\\Teamcenter11\\install\\install\\patches\\backup" date="201812102037" version="11000.2.3.30" parentVersion="" applicationId="ActiveWorkspace" />
</updateManager>
</root>
Thousif
@Lumi
why you haven't introduced these urls?
BR.
maybe a problem not related to Teamcenter?
look there: http://www.nttdatasitecore.com/Blog/2018/February/SolrCore-Initialization-Failures
@Roman65 - Hello, I tried that too. didnt work for me.
@JFK1963 - I have installed client extensions on another server, hence it didnt prompt me these values during Indexing Engine setup.
Thousif
@Lumi
You must complete client and server side setup and you should be able to log in to AWC. Solr Indexer setup will prompt for the 4-tier url, see attach.
You can run TEM and modify your setup after AWC is up and running.
BR.
@JFK1963
your screenshot is prompting for the TC 4-tier URL, not the AWC URL
@Roman65
Thanks. you are right I just write AWC anywhere without care. I will edit my reply now.
BR.
My AWC is up and running. I'm able to launch awc client and login without any issues.
I'm getting this error when I installed "Active Workspace Indexing Engine"  service as part of Indexing Engine setup.
Thousif
It should not be required to run solr as Administrator.
I just tried with a new install of solr on Server 2016, started runSolr.bat and it is up and running
try to activate DEBUG logs, you find the log4j.properties under %TC_ROOT%\solr-6.2.1\server\resources
change log4j.rootLogger=INFO, file, CONSOLE to log4j.rootLogger=DEBUG, file, CONSOLE
