Type definition for objectdata does not exist - Active Workspace Indexing
After AWC 3.4 installation first time,
I am indexing with runTcFTSIndexer.bat -task=objectdata:index
I am getting error :
java.rmi.RemoteException: Type definition for objectdata does not exist. Supported Type [objdata, structure]
Service is already started using runTcFTSIndexer -service
Also, as per AWC Configuration guide, reason for same is "Active Content Structure features are not installed.". It is already installed.
What is missing? Any Preference / Configuration in Properties file before this?
I assume there is only "Active Content Structure" and not any other than this.
TIA,
Akash
Teamcenter 11.4 with AWC 3.4
Re: Type definition for objectdata does not exist - Active Workspace Indexing
Try using  -task=ojbdata:index  not  -task=objectdata:index. Your error message is also telling you this, only objdata or structure is supported.
Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
