UGMANAGER_CLONE import not working!
Hi All,
I could not execute ugmanager_clone import option, i am facing an error "Teamcenter Integration is not initialized while initializing import operation", Please find the attachment for snap.
i have gone through a similar issue posted in this community page, but not solved fully.
Thanks in advance.
-AJ
-AJ
Re: UGMANAGER_CLONE import not working!
I don't see the "-pim" argument in your command line. The NX help docs show this example:
ugmanager_clone -pim=yes -u=<userid> -p=<password> -g=<group> -o=import -par=12345_A.prt
-default_n=autotranslate
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
Hi ardenb,
Thank you for the reply.
I tried using -pim=yes , here the problem was LDAP/SSO .. i was using tc login credentials instead of SSO login credentials.
Moreover the ugnx document says, ugmanager_clone forces -pim=yes , thats the reason. i have not used -pim tag.
Any how the solution here is "Use SSO credentials
Please find below for the UGNX document says about ugmanager_clone script,
"ugmanager_clone script
ugmanager_clone is a script which wraps around the ug_clone utility, ensuring that the correct Teamcenter environment is set up and forcing the -pim=yes argument.
The ug_clone utility can be called from either native NX or from Teamcenter Integration. Calling this utility from Teamcenter Integration requires that the Teamcenter environment be set up. Using the ugmanager_clone script eliminates the need for this step."
-AJ
-AJ
