Unable to create Business Object
I took a project to make some customizations. However when I try to create a new item it encounters a pop up as the screenshot below. I also created a project and assigned the item to this project before finish the creation, but it doesn't solved the issue. I also put the RAC log file at the attachment.
Thanks in advance ,
4 REPLIES 4
Re: Unable to create Business Object
Looking at the error message, i think there is a condition defined in BMIDE that allows users to create this item only in context from a Program.
So make sure you have selected a Program in your session before attempting to create this item.
Thank you for your answer @123123 I made something as you mentioned, I create a project and assign the item before create it, The project's screenshot (use program security) is below. However it doesn't solve the problem. How could I select a program?
Is there any idea about this issue? If someone know the steps that I should to do for creating an item without this issue, could he/she help me? Thanks in advance,
create a project and assigned the user to this project as a "privilege user". In session ; I assigned the project to this user. I checked and delete some custom attributes in BMIDE. After restart it's done. To your information.setpriviligedUser.JPG
session.JPGI
