cancel
Unable to login to 2T client with error ERROR_STRING_BAD_MESSAGE_TYPE
Hi All,
When i try to login to 2T client(TC11.2), got the error ERROR_STRING_BAD_MESSAGE_TYPE.
Restarted the FSC, but no luck, Please suggest.
Phani
Re: Unable to login to 2T client with error ERROR_STRING_BAD_MESSAGE_TYPE
Issue got fixed. In the same machine i have two environments. FMS is pointing to other FSC.
