Unable to unzip tc/fsc.zip while patching
I am trying to update patch,
but it shows unable to unzip tc/fsc.zip due to file in use
But i have stopped all services
tried to run manually also, but same result
C:\Users\tcadm>"d:\splmlocal\int01\appl\tc112\install\install\unzip" -o -d"d:\sp
lmlocal\int01\appl\tc112" "I:\TC\Tc11.2.3.1_a01_patch_5_wntx64\wntx64\tc\fsc.zip
Archive: I:/TC/Tc11.2.3.1_a01_patch_5_wntx64/wntx64/tc/fsc.zip
inflating: d:\splmlocal\int01\appl\tc112/fsc/fmsmaster.xml.template
inflating: d:\splmlocal\int01\appl\tc112/fsc/fsc.properties.template
inflating: d:\splmlocal\int01\appl\tc112/fsc/fsc.xml.template
inflating: d:\splmlocal\int01\appl\tc112/fsc/fscadmin.properties.template
error: cannot delete old d:\splmlocal\int01\appl\tc112/fsc/jar/fmsservercache.j
ar
error: cannot delete old d:\splmlocal\int01\appl\tc112/fsc/jar/fmsutil.jar
inflating: d:\splmlocal\int01\appl\tc112/fsc/jar/fscclient.jar
error: cannot delete old d:\splmlocal\int01\appl\tc112/fsc/jar/fscjavaclientpro
xy.jar
inflating: d:\splmlocal\int01\appl\tc112/fsc/log.properties
inflating: d:\splmlocal\int01\appl\tc112/fsc/log4j.xml
inflating: d:\splmlocal\int01\appl\tc112/fsc/monitoring/fscMonitorConfig.xml
inflating: d:\splmlocal\int01\appl\tc112/fsc/monitoring/fscMonitorConfigInfo.x
ml
inflating: d:\splmlocal\int01\appl\tc112/fsc/monitoring/healthMonitorV1.0.xsd
inflating: d:\splmlocal\int01\appl\tc112/fsc/pref_export.xml.template
error: cannot delete old d:\splmlocal\int01\appl\tc112/fsc/third_party/OnionNet
works/webraid-2.6.8_01/lib/jdom.jar
works/webraid-2.6.8_01/lib/onion-common.jar
works/webraid-2.6.8_01/lib/onion-wantransport-tools.jar
works/webraid-2.6.8_01/lib/onion-webraid.jar
works/webraid-2.6.8_01/lib/onion-webraidutil-tools.jar
works/webraid-2.6.8_01/lib/onion-webraidutil.jar
error: cannot delete old d:\splmlocal\int01\appl\tc112/fsc/third_party/TcSS/TcS
S11.2.1.20151112/jars/teamcenter_sso_applib.jar
S11.2.1.20151112/jars/teamcenter_sso_common.jar
S11.2.1.20151112/jars/teamcenter_sso_webtoolkit.jar
error: cannot delete old d:\splmlocal\int01\appl\tc112/fsc/third_party/commons-
codec/commons-codec-1.3/commons-codec.jar
collections/3.2.2/commons-collections-3.2.2.jar
httpclient/commons-httpclient-3.1/commons-httpclient-3.1.jar
logging/commons-logging-1.0.4/commons-logging.jar
error: cannot delete old d:\splmlocal\int01\appl\tc112/fsc/third_party/javamail
/1.3/mail.jar
inflating: d:\splmlocal\int01\appl\tc112/fsc/third_party/jetty/9.2.0/jetty-cli
ent-9.2.0.v20140526.jar
error: cannot delete old d:\splmlocal\int01\appl\tc112/fsc/third_party/jetty/9.
Re: Unable to unzip tc/fsc.zip while patching
Hello, maybe this help:
Close in Task Manager Java process associated with fsc if you find it in the Task Manager and try updating again
If this does not work, try manually cutting out the old files with errors from the log and and try updating again
when the error comes up during patching, rename Fsc\fsc\bin\TcFSCService.exe
and then click retry, and it should work
Worked for us
BR
Both @Arthur3 and @Roman65 are right. Sometimes there are left-over "Teamcenter" processes running even after shutting down Server Manager. After shutting down the environment, run "clearlocks -verbose" then check Task Manager and kill any running processes named "Teamcenter" or "java.exe". That should free up the locks.
If the TcFSCService.exe is still being stubborn then renaming (you cannot delete it) it will allow the new one to be installed. After installation/patch then you can delete the renamed (old) TcFSCService.exe.
