Unit of Measure in PLMXML Export
Hi all
Is there a trick to getting unit of measure to show up in PLMXML Exports? I have tried many combinations of values in my property set with no results whatsoever. Perhaps I need to add to my closure rule, since it is a reference to another item type vs a regular property...
Any help is appreciated. I've been stuck on this one for a while. Attached is my closure rule.
Aaron
3 REPLIES 3
Re: Unit of Measure in PLMXML Export
Not at my pc... but, doesn't uom reside on the item?
Rich
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Try adding these lines to your Closure Rule:
Create a Property Set:
Results show uom:
Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
This worked for the BOMLine uom_tag. The uom_tag is in there as a blank value. Is there a way to get that to populate?
For a little context, I am using this to migrate item and BOM data into our ERP system. If I release an item that is not associated with a BOM, I still won't get a uom value to come through.
