Unlock ID column when Import NX assembly into Teamcenter
Solution Partner Innovator Solution Partner Innovator
Hi to all expert here,
May I know whether I can unlock the ID column when I do Import NX assembly into Teamcenter?
Currently I'm using Attribute as numbering source. Then I leave ID attribute empty as I tought it will unlock the ID column.
Currently I want to copy Object Name column ans paste into ID column. I do not want to use Teamcenter running Number.
Even I try to use different Numbering Source, it will keep ID clumn to be lock.
Umlock ID column.jpgCopy Object Name into ID column
Re: Unlock ID column when Import NX assembly into Teamcenter
@Arisy  - Try setting this preference: ASSIGNED_ITEM_ID_MODIFIABLE=1
Jamie Griffis | PLM Solution Architect | Engineering USA
Hi @Jamie_Griffis
It works. Many thanks!
