Upgrading a TC site from TC2007 to TC10
<->Hello All,
There is a requirement to upgrade from TC 2007 to TC10.
has anyone upgraded  from TC2007 to TC2010?
IF yes, can you please share the process used.
Thanks in advance
Jay
Re: Upgrading a TC site from TC2007 to TC10
It is not Tc2010, it is Tc10.1 ;)
What database do you use currently?
What server operating system do you use currently?
Make sure to have your migration tested by a knowledgeable Siemens consultant, they have more information about gotchas and such.
Employees of the customers, together we are strong ;)
Hi
You need to it in steps since it's not supported to go from 2007 to TC10.1 in one step.
I think you need to go to TC9 first and then to TC10.1.
What I seen is that you can skip one version but if you skip two it will give you alot of more work for the upgrade.
We are right now in the process of upgrading from TC8.3 to TC10.1.
Good luck!
Jörgen Mähler, PLM Lead Hydro
TC11.5 | TcIC11.5 | Swim 11.4 | Supplier Collaboration
NX 11,12 | Catia V5 | Solidworks 2018 | AutoCad2018
Thanks for your reply....
After posting this question, we found out that we are supposed to take the route of 2007  --> 9.1 --> 10.1
We are in that process now....
have you tried your upgrade on a test env?
regards,
Jay
We always have a Siemens consultant do the upgrade in a test environment, when he is sure that the upgrade succeeds, our test environment will be migrated.
After we have verified that our test environment is OK, our production environment is migrated.
Sure it takes time, but the consultant can report problems early and get workarounds or even solutions to problems he encounters during the migration.
Testing in a test environment at our site has the advantage to be able to find any remaining problems, so the migration of the production environment should be painless.
Sure there is always the possibility to have some things that will only surface in the production environment, but the amount is very small after heavy testing.
