Re: User Login History
@RandyEllsworth
Hi Randy,
I am trying to create a summary report in Report Builder.
I have my query and property set ready; however to write down xsl stylesheet to define report layout; I need to know the TCXML schema, tags to fetch values, How can I get xml format..?
I tried generating report without mentioning xsl format hoping it would open the results in XML format; however It popped up error message.
Could you guide me on how to get hold of XML.
I get the XML by running the report then generate the XSL to format it the way I want it to look. After which I can apply the XSL in Report Builder so that future reports look the way I want. The first step is getting the report to run successfully before trying to pretty it up. But I may not understand your issue?
Evaluating: AW 3.4
Thanks for reponse @RandyEllsworth
I am trying to generate report to get xml (without specifying any xsl, ideally that should give me xml version)
but teamcenter is throwing error for ANY report if I dont provide any xsl(previously working fine)
This looks like product bug.
Thanks again @RandyEllsworth
Yes, There is issue with TC 11.3 + windows 7. I could generate the xml on server machine.
Got an IR opened.
