Using Excel Live to Update Item and ItemRevision Properties
I've installed the "Teamcenter Extensions for Microsoft Office" and created a custom excel template for exporting property values via Excel Live (Tools > Export > Objects to Excel). However, I'm only able to get the property values from the Item and not the ItemRevision which remain blank.
Does anyone have a working example of an excel template that exports both the Item and ItemRevision properties at the same time? For instance, the following data model explanation:
Item
  • item_id
  • item_name
ItemRevision
  • revision_id
  • owning_user
I would like all the properties to be listed on a single line in the exported excel spreadsheet.
Best,
/Randy
Evaluating:AW 3.2
