Warning message, what is it telling me?
When user starts a work flow on this item revision, this warning pops up.  Release workflow seems to continue without incident, but it must be trying to tell me something.
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
Re: Warning message, what is it telling me?
You'll need to set full debugging and capture the tcserver sylog for GTAC. Usually "The instance is not loaded." error is related to a bad assumption (bug) in the software that need to/will be resolved in a future version. You'll have to open an IR/PR with your particular use-case.
Evaluating:AW 3.2
