WebClient always returns initial values
We used a SOA (java) to take data from Teamcenter. It takes form properties from a released item. When the first time it takes the object from TC, it reads all properties values correctly. We check-out the form, change the properties values, check-in the form and refresh the item. After do the change, we tried to take properties values again, but it returns old values from WebClient. What we do? Is there a specific cleaning method to clean cached data?
Re: WebClient always returns initial values
If we create new form under the item and delete the old one. It returns new data, because the object uid of the form changed. It acts like a new form, not cached one.
