What's mean about Error_515023?
Hello All
When I login TC
It show Error_515230
Web-tier & AWC  would be the same error
Best Regards
David
Teamcenter 11.4,Active Workspace 3.4
Solid Edge ST10
6 REPLIES 6
Re: What's mean about Error_515023?
In previous TC version this can be mean as
515023: POM_invalid_enquiry_id
 The enquiry_id does not refer to an existing enquiry.
 Check whether the enquiry has been deleted or if the create enquiry failed.
Hello alex_c
How to check enquiry?
Where I can find it?
thank you!
Best Regards
David
Solid Edge ST10
Hi Alex,
How to check enquiry created or not ?
how to create enuiry ...
I am getting error on Server manager console as below:
ERROR - pni6w2606.07115.01.Anonymous.00001.Mgr - 2018/07/24-10:22:53,046 UTC - pnv6s789 - 515023: The enquiry ID is invalid.:
com.teamcenter.jeti.serversubpoolmanager.TctpGatewayService.invoke(Unknown Source) com.teamcenter.jeti.serversubpoolmanager.T
ctpGatewayService
Please revert and appreciate your thoughts or solution for the same.
Best guess, looks like your T4x (Gateway) is referencing a query that doesn't exist in Tc?
Evaluating: AW 3.4
Can you please let me know how to check queries or create query for T4x Gateway?
Deepak
Building queries will likely involve writing TCL in T4x. You may need to review TCL to check the queries too but the first thing I would do is run your use-case again to get the error then log into the BGS/GS Admin GUI and review the logs. It will likely point to the query missing in Tc. Your other option is to engage w/the Tesis team.
Evaluating: AW 3.4
