Where can we download ipemsetup
Hello
Good Morning!
Where can we download ipemsetup? I would like to install on my test server with Solid edge. SE is insallated already.
Venny
Re: Where can we download ipemsetup
The ipemsetup file is part of the "Teamcenter Integration for Creo" (a.k.a Pro/E, IPEM). It has nothing to do with SE that I'm aware of. The SE integration is SEEC.
Randy
You are right and correct. I have TC with Solid edge in my test server. I got new lic file for Creo/Proe integration. I would like to install Creo/Proe integration, I went to download the IPEM in GTAC, I could not find out where it is. If someone guides, it would be helpful.
The GTAC downloads page will only show the software that you are licensed for. This is based on the Sold-To registered with your webkey account. You log into GTAC with your webkey. If you have a "new" license with a different Sold-To then you'll need to tie the new soldto to your existing webkey account in order to see the software listed in that license. Path to IPEM is:
Randy
Thanks for info. I will try as you suggested
