WhereReferencePOMPref question
Honored Contributor
Honored Contributor
We had a small issue here, so GTAC had me enable this option in the Impact Analysis.  That worked, and the issue is resolved, but currently the option is available in the Impact Analysis drop down for everyone.  I would like to have it only available for dba types, is this possible?  and if so, how would I do it?
My gut tells me it would be dangerous to let everyone have access to this?
-Dave
4 REPLIES 4
Re: WhereReferencePOMPref question
You can set the preference "WhereReferencePOMPref" with the value "1" as a group preference for dba only. That way your users will not be able to use it.
--Jelle
Honored Contributor
Honored Contributor
Excuse my ignorance here, but the only option i see that has "group" is the Protection Scope, is that what I need to change?
-Dave
Dave,
No worries.
On the organization view in the preferences (see lowest line on the left). First select organization and select the desired preference. Then select the dba group (in this case) and press the upper left button "Create a new preference instance". Now it is a group preference too. On site/organization level you can set it to "0" and on the group level to "1"2017-02-01_160914.png
Hope this helps a little...
--Jelle
Honored Contributor
Honored Contributor
Thanks Jelle, I got it!!
-Dave
