Which search operator has to be used to search in Structure Manager search panel for blank space
The "Item name" has value "test empty". There is a space between the two words in the value. Which search operator has to be used to search this in "Structure manager search panel". I tried Parentheses, asterik, question mark, quotation marks etc. with no success. Any help in this regard would be highly appreciable.
4 REPLIES 4
Re: Which search operator has to be used to search in Structure Manager search panel for blank space
I use the "Find Components in Display" at the bottom of the window. It doesn't have an issue with spaces. See screenshot.
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Thank you for you answer. But, I actually expecting the same behavior from "Item Attribtues" section available in "Structure manager search panel" as in the snapshot below. Is there a way to get same behavior here?
That is the spatial search. Is that configured to be used in your system?
Jamie
you can use *  as wildcard
searh name=testing*black*
or
BOM Line=testing*black*
Saludos,
