Workflow: Condition Task by the USERGROUP
Hi everybody,
perhaps one of you know what we can do.
How I can create a "condition task" into a workflow and the way choose by the system depends the group of the user (Starter of Workflow).
Example: If I work on R&D, the workflow go directly to the way 1, If I work on Purchase department, the workflow go directly to the way 2!
Thank you for your help
Best Regards
PLM Technical IT
Re: Workflow: Condition Task by the USERGROUP
You could use epm-set-task-result-to-property to check the owning group of ItemRevision. If R&D then define custom Result with that name. Try it might help.
With Regards,
Chini
Hi
thank you for your answer, it's exactly what I need.
PLM Technical IT
