Workflow assign task to multiple user
Hi there,
Anybody knows if is there a way to assign the Do Task or the Review Task to multiple user without using Resoursing Pool or Address List?
I would like to use EPM-Fill-in-Reviews or EPM-adhoc-signoffs like the image below.
image.png-assignee...
Best Regards.
6 REPLIES 6
Re: Workflow assign task to multiple user
Good afternoon, try the following solution:
EPM-adhoc-signoffs
-assignee=user:vinicius, user:tiago
You can also add an argument:
-auto_complete
Hi @ArthurRM
Thanks, but that does not work to me.
@bauler , here is my example, it works for me:
Hi @ArthurRM
I've tested using Do Task, do you know if it works?
No, it does not work for me, I think that the Do Task can only have one responsible party (user or resourcepool)
@bauler  - When you want to assign multiple people, use an Acknowledge task instead of a Do task.
Jamie Griffis | PLM Solution Architect | Engineering USA
