Workflow fail
I am not able to create new templates on workflow designer. please find the attached image. could you help me to fix?
Venny
Re: Workflow fail
Looks like someone deleted 'process' template from your TC environment.
You can verify the same by looking process template by name 'process' in Workflow Designer.
Locate 'base_template.xml' plmxml file in your TC_DATA folder and import it into your environment to restore missing templates
You can reimport them using the below command
plmxml_import -u=infodba -p=${TC_USER_PASSWD} -g=dba -xml_file=${TC_DATA}/base_template.xml -transfermode=workflow_template_overwrite
Mahendra
Re: Workflow fail
Mahendra,
Yes, you are right. i deleted process' template. Now fixed.
