Workflow tab in AWC
I could not see the workflow tab which I suppost to see in AWC. I already have installed workflow feature. Any pointers on this?
Br,
Rupesh
6 REPLIES 6
Re: Workflow tab in AWC
Were you able to solve it?
I have reported the same issue with GTAC, they said it is broken in AWC 3.4 and converted my IR to PR
Rafa
Rafa
Hi Rafa,
No, it's not resolved yet. For us, it works in Test but not in production. It works well when Siemens tested it in their environment. We already compared Test and Prod and it looks correct, not sure where exactly issue is.
Br,
Rupesh
Hi Rupesh,
Do you have any custom changes for the change object like special XRT rendered in AWC client?
Rafa
Rafa
Hi Rafa,
Yes, we do. But those are also verified and look correct.
Br,
Rupesh
Hi Rafa,
Finally issue was fixed. There is a dataset named Cm1MaturityProgressViewer in Cm1ChangeNoticeRevisionSummary.xml stylesheet(open this xml file and search Cm1MaturityProgressViewer)  which was not imported during AWC installation due to some unknown reasons. I imported it manually and I could see workflow maturity.
Br,
Rupesh
Hi Rupesh,
Thanks for the update!!
We do have a similar fix, but our change management is driven by custom stylesheets and I see the below line was missing
"<inject type="dataset" src="WorkflowSummary"/>"
After adding this line, I could see the workflow tab.
Rafa
Rafa
