Workflow template is not visible for non-dba user
Hello.
For some reason workflow template is not visible in workflow templates list (and therefore not available) for non-dba user, when it want to create workflow. In case of user from dba-group - workflow is visible and available without any problems.
Workflow template is in published state (without triangle in Workflow Editor). So it is not a reason.
What could be wrong?
I am not admin of this server. Is it possible to block workflow visibility/availability for some user groups?
1 REPLY 1
Re: Workflow template is not visible for non-dba user
Yes, its called workflow filtering. And it is achieved using different methods depending on your version of Teamcenter.
Siemens Tc Help server is down right now so I cannot provide a link. Once Tc help is available again then you can search for these:
Legacy Setup
CR_allow_alternate_procedures=none
TC_<object_type>_release_procedure=list of allowed workflows (deprecated in Tc11.2)
WRKFLW_use_legacy_template_filter=true (new in Tc11.2)
Filter Condition (Tc11.2+)
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Condition-for-Workfl...
