Workflow to query item status
Hello Experts,
I am building a workflow that will search through all revisions and check the status. The idea is that at no point will there ever be two released revisions for an item. Currently, I have it built that it only checks previous revisions. For example,
Item
     Rev A - Hold
     Rev B - Hold
     Rev C - Hold
     Rev D - Released
Lets say I want to release rev C because rev D is not performing as expected. When I run my workflow on rev C, the workflow checks all later revisions. So, rev B is Hold and rev A is Hold therefor the workflow progresses and rev C is released. But, rev D is also released and I now have two released revisions.
How can I make it so that the workflow will search the entire structure for revision statuses? Or, has anyone performed this action/something similar before?
Ideally, in my scenerio above an error would occur prior to release.
Thanks for your help, as always
Re: Workflow to query item status
We are just going to work around this. Having a do task for the operators to double check for additional released items. To check all previous revisions, use a validate task.
-previous_status:SP5_Hold
-previous_check:all
-stop:Y
-current_check:all
