Do you mean
Reply
Solved! Go to solution
Write messages in syslog using SOA services
Hi folks!
Does anybody know is it possible or not using ootb SAO services to write messages in tcserver.syslog.
I know how to do it using ITK, but I could not find any related methods from SOA services.
Kind regards,
Denis
Re: Write messages in syslog using SOA services
All I can think of is create an SOA wrapper to your TC_write_syslog ITK function and call it from your SOA client
Mahendra
Hi Mahendra,
Thank you for your reply! Yeah I thought about it. Just wanted to check that there is no OOTB java tools to achive this.
Denis
Mahendra,
I've never worked before with c functions from Java.
What are using for that, JNI (Java Native Interface) or something else?
Solution
Solution
Accepted by topic author akhmetov
‎01-31-2017 08:35 AM
Though I am not sure how feasible it is to directly write to syslog, I can suggest getting absolute path to syslog using API "getTCSessionInfo". The GetTCSessionInfoResponse contains Hashtable ExtraInfo. You can get absolute path to syslog using key "syslogFile".
Hi xplm2005,
Thank you for your valuable advice!
Without your hint it was impossible for me to find this value in API documentation.
Yeah, writing with Java tools to syslog file does not work properly but it's ok and enough for my syslog parser.
Denis
I wrote it all from C# .net point of view. But there should be a call similar to getTCSessionInfo in java.
Ok,
Here is Java way to get it:
Map<String, String> extraInfo = session.getConnection().getTcSessionInfo().extraInfo;
