XML Rendering Stylesheet Error
Has anyone else ever experienced this error when applying changes made to an XMLRenderingStylesheet?
"Entry point (Nxl3_dataset_import_post) not found in library name (libNXl3_extension_library) specified by () preference."
attached image of error as well.
by the way this is what pops up when clicking "apply" after making changes to an existing XMLRenderingStylesheet.
any input is greatly appreciated!
Jake
4 REPLIES 4
Re: XML Rendering Stylesheet Error
Did you launch IDNPortal.bat or just portal.bat when editing the stylesheet?
Evaluating: AW 3.4
Just portal.bat
Jake
The error is showing that it cannot find the NXIdeas library. Although, why they're needed for a rendering stylesheet, I have no clue (save-as button?). Try it again after launching IDNPortal.bat.
Evaluating: AW 3.4
Thanks for your response Randy,
The I was actually an L, it ended up having to do with our NextLabs integration. I was able to find all of the necessary files and resolve the error.
Jake
