XML style sheet of SaveAs UI
How we should edit XML style sheet for our own item   SaveAs UI.?
I want to fill in the custom properties in the Save As interface。What is the grammatical structure?
it was not work。
Best Regards
Re: XML style sheet of SaveAs UI
Good afternoon, I checked it myself and I have the same result as yours - it does not work. My version of Teamcenter 11.2.3.
I think you should go the other way. Use the Operation Descriptor tab and SaveAsInput operation, I think this should work.
Links to documentation:
https://docs.plm.automation.siemens.com/tdoc/tc/11.2.3/help#uid:xid1256815:index_plm00071:id166716:x...
Manage create and save as operations on business objects
https://docs.plm.automation.siemens.com/tdoc/tc/11.2.3/help#uid:xid1256815:index_plm00071:id166856:x...
Manage business objects for the Save AsInput operation
