am_rule_harness_test for BOMView Access
I am trying to use the am_rule_harness_test.bat file for testing the ACL which I have added in my environment.
When I give searchCriteria for searching a particular Item of one Item type in input xml file, its working fine and giving me result.
But now I want to test the access for the BOMView of that same Item type and I am giving searchCriteria as
  • BOMView Revision{bom_view=344477-View} --> Not working
  • BOMView Revision{current_name=344477/001-View} --> Not Working
  • PSBOMViewRevision{current_name=344477/001-View}--> Not Workin}
Is there anyone who can help me on identifying the correct searchCriteria for the BVR to see the access?
Re: am_rule_harness_test for BOMView Access
Hi all,
Can somebody help me on this???
Thanks in Advance.
Below you can find basic script, but you can change the search Criteria by using Query/Report manager  to find it is own objects(Always use real name od the BO).
<TestSuite name="Test Suite 1" description="This test suite will test x,y,z">
  <UserTest description="Tests for Item1" user_id="u1" group="Engineering" role="Designer" project="" searchCriteria="ItemRevision{item_id=000052,item_revision_id=A}">
    <PrivilegeTest privilege="READ" expectedResult="Grant"/>
    <PrivilegeTest privilege="WRITE" expectedResult="Grant"/>
    <PrivilegeTest privilege="DELETE" expectedResult="Grant"/>
    <PrivilegeTest privilege="CICO" expectedResult="Deny"/>
    <PrivilegeTest privilege="EXPORT" expectedResult="Grant"/>
    <PrivilegeTest privilege="IMPORT" expectedResult="Deny"/>
  </UserTest>
</TestSuite>
